[Qgis-user] Deleting a column from attribute table
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Jul 27 08:23:05 PDT 2011
use the "table manager" plugin.
cheers
-- Giovanni --
On Wed, 2011-07-27 at 08:19 -0700, adamu eloji wrote:
> Dear All,
> As a novice in QGIS, i created a column on an attribute
> which i dont want any more, pls can any experience person tell me how
> to delete the column.
> Thanks
> El-Oji
> --- On Wed, 7/27/11, qgis-user-request at lists.osgeo.org
> <qgis-user-request at lists.osgeo.org> wrote:
> From: qgis-user-request at lists.osgeo.org
> Subject: Qgis-user Digest, Vol 65, Issue 61
> To: qgis-user at lists.osgeo.org
> Date: Wednesday, July 27, 2011, 11:14 AM
> Send Qgis-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more
> specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Re: object labels (Andreas Neumann)
> 2. RE: QGIS -> MySQL -> Mapserver ?? (Chris Green)
> 3. RE: QGIS -> MySQL -> Mapserver ?? (Saber)
> 4. DTclassifier is released (Maxim Dubinin)
> Message: 1
> Date: Wed, 27 Jul 2011 11:00:01 +0200
> From: Andreas Neumann <a.neumann at carto.net>
> Subject: Re: [Qgis-user] object labels
> To: <qgis-user at lists.osgeo.org>
> Message-ID: <2634cc5e1e8f0d3a1c3ecba07210ba79 at carto.net>
> Content-Type: text/plain; charset=UTF-8; format=flowed
> Hi,
> Currently, you have to create a new column. I usually create a
> view in
> Postgis for this purpose.
> It is in on the wishlist that one can create a "virtual"
> column - not
> only for labeling, but also for map tips and perhaps
> symbolization.
> Until then you have to do it yourself.
> Andreas
> On Tue, 26 Jul 2011 22:51:34 +0200, Torsten Lange wrote:
> > Hi,
> > Is there a way just to print - lets say - the first four
> letters of a
> > objects
> > name? Or must I create a new row for that?
> > Thank you, Torsten
> > Qgis-user at lists.osgeo.org
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Message: 2
> Date: Wed, 27 Jul 2011 10:00:27 +0100
> From: "Chris Green" <chris.green at ibstv.co.uk>
> Subject: RE: [Qgis-user] QGIS -> MySQL -> Mapserver ??
> To: "'Saber Razmjooei'" <razmjooeis at faunalia.co.uk>
> Cc: qgis-user at lists.osgeo.org
> Message-ID: <02a401cc4c3b$a25fa3a0$e71eeae0
> $@green at ibstv.co.uk>
> Content-Type: text/plain; charset="us-ascii"
> Hi Saber
> Thanks for the suggestion. When I run ogrinfo -formats I see
> that MySQL is
> included, so that is not the problem.
> It seems that the issue is about the way that I created and
> store the line
> data, because I have tried with some point data and I don't
> have this
> problem - I can create, save, and display points with QGIS and
> then both OGR
> and MapServer are OK. But with line data it is different.
> I can only assume that QGIS is sending the line data to MySQL
> in a format
> that QGIS recognises when the data is retrieved, but which is
> not recognised
> by OGR / MapServer.
> Going to PostGIS would have to be a last resort, I have a lot
> of effort
> invested in MySQL ..
> Chris
> From: Saber Razmjooei [mailto:razmjooeis at faunalia.co.uk]
> Sent: 27 July 2011 09:35
> To: Chris Green
> Subject: Re: [Qgis-user] QGIS -> MySQL -> Mapserver ??
> Chris
> I presume your ogr can handle mysql if you can open it in
> QGIS. But to
> confirm could you run:
> ogrinfo --formats
> from terminal and check if you have
> -> "MSSQLSpatial" (read/write)
> Is your database large? Have you considered using PostGIS?
> Cheers
> Saber
> On 27/07/11 07:45, Chris Green wrote:
> Hi QGIS users
> I have a problem getting Mapserver to display vector line
> features which I
> created with QGIS and saved as spatial objects in MySQL...I
> asked for some
> advice on this from the Mapserver forum yesterday but had no
> responses,
> perhaps someone in this forum has some experience to offer?
> As explained in the question below, I can create line features
> in QGIS, save
> them in a MySQL table, and recall and display them with QGIS
> without any
> problem. But the same features do not appear to be recognised
> by OGRInfo or
> by Mapserver. The line features are saved as BLOB data in a
> MySQL MyISAM
> table in a column which is defined as type 'geometry'. MySQL
> can create a
> spatial index of these features.
> The table is accessed by QGIS as a database layer via the 'Add
> Vector Layer'
> dialogue. I am using QGIS 1.7.
> It's not really a QGIS problem, but I spent all day wrestling
> with this
> yesterday but have not solved it. Any suggestions?
> Chris
> I'm having some trouble with an OGR connection to a MySQL
> database. The data
> I'm trying to access was created using QGIS as a line layer
> and saved in a
> MySQL table as a BLOB in a geometry column. I can access and
> properly
> display this line data using QGIS, but not so far via
> Mapserver - nothing is
> drawn and I can't see any error.
> I am using Mapserver 6.0 and my mapfile is very similar to the
> example in
> theMapserver / MYSQL documentation:
> LAYER
> NAME "testLine"
> TYPE LINE
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION
> "mysql:testDB,user=admin,password=password,port=3306"
> DATA "SELECT Geometry from testLine"
> CLASS
> STYLE
> COLOR 0 0 0
> WIDTH 2
> END # style
> END # class
> END # layer
> If I look at the MySQL table using OGRinfo I see the
> following:
> Layer name: testLine
> Geometry: Unknown (any)
> Feature Count: 0
> Layer SRS WKT:
> (unknown)
> FID Coumn = id
> Geometry Column = Geometry
> The issue seems to be that OGRInfo and therefore MapServer
> does not
> recognise any features in the table, but QGIS using access to
> the same table
> finds and displays the features.
> Anyone have any ideas what I am doing wrong?
> Chris
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/414a5aee/attachment-0001.html
> Message: 3
> Date: Wed, 27 Jul 2011 10:55:20 +0100
> From: Saber <razmjooeis at faunalia.co.uk>
> To: Chris Green <chris.green at ibstv.co.uk>
> Message-ID:
> <05cdp715sy1xrat8ywciguee.1311760349356 at email.android.com>
> Content-Type: text/plain; charset=utf-8
> As a test, worth converting the mysql vector to shapefile to
> see if the vector is shown properly.
> Also checking webserver logs report for mapsever requests of
> the MySQL vector might help.
> Chris Green <chris.green at ibstv.co.uk> wrote:
> >Hi Saber
> that MySQL is
> store the line
> have this
> and then both OGR
> in a format
> not recognised
> >by OGR / MapServer.
> of effort
> >Chris
> >To: Chris Green
> >Chris
> QGIS. But to
> >ogrinfo --formats
> >Cheers
> >Saber
> >Hi QGIS users
> features which I
> asked for some
> responses,
> features in QGIS, save
> without any
> recognised by OGRInfo or
> MySQL MyISAM
> can create a
> 'Add Vector Layer'
> with this
> >Chris
> database. The data
> and saved in a
> properly
> the example in
> >LAYER
> > NAME "testLine"
> > TYPE LINE
> > STATUS DEFAULT
> > CONNECTIONTYPE OGR
> > CONNECTION
> > CLASS
> > STYLE
> > COLOR 0 0 0
> > WIDTH 2
> > END # style
> > END # class
> >END # layer
> following:
> >Feature Count: 0
> >Layer SRS WKT:
> >(unknown)
> >FID Coumn = id
> does not
> the same table
> >Chris
> Message: 4
> Date: Wed, 27 Jul 2011 14:09:39 +0400
> From: Maxim Dubinin <sim at gis-lab.info>
> Subject: [Qgis-user] DTclassifier is released
> To: qgis-developer at lists.osgeo.org
> Message-ID: <77239752.20110727140939 at gis-lab.info>
> Content-Type: text/plain; charset=us-ascii
> Hi all,
> To follow up on our demonstration in Lisbon.
> We are happy to release our new plugin for streamlined remote
> sensing
> data classification in QGIS [0]. Initially the
> plugin was
> developed to provide easy to use tool to monitor
> forest cover
> change, but it can be used to classify any type of targets.
> Main features:
> - all-in-one, with this plugin only QGIS is needed for all
> steps of
> classification;
> - decision trees, the plugin is using computer vision
> library OpenCV to
> implement modern classification algorithm typically not
> available in
> other software packages (both OS and proprietory);
> - performance, another nice feature of OpenCV is
> that it is
> very fast;
> - multiple input rasters and multiple training layers;
> Description, examples and sample data:
> EN: http://gis-lab.info/qa/dtclassifier-eng.html
> RU: http://gis-lab.info/qa/dtclassifier.html
> Right now the windows binaries and source code are available.
> Maxim
> [0] http://www.nextgis.ru/projects/dtclassifier
> End of Qgis-user Digest, Vol 65, Issue 61
