[Qgis-user] Can not remote access PostGIS layers
Nomeneta Saili
nome.saili at gmail.com
Wed Jul 27 13:25:43 PDT 2011
Hi people,
I have set up PostGIS on my server and i am able access the GIS layers
posted on it using the hostname : localhost on the server itself.
However when i try to access the PostGIS layer from another computer
using the hostname : GIS-SERVER (Server name on our network) it can't
access. A popup menu ask for credentials with an error message can not
translate host name.
Any help would be much appreciated.
Thanks,
Nome
On Wed, Jul 27, 2011 at 9:24 AM, <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Re: KML to GoogleEarth (percy langa)
> 2. RE: QGIS -> MySQL -> Mapserver ?? (Chris Green)
> 3. RE: QGIS -> MySQL -> Mapserver ?? (Saber Razmjooei)
> 4. Deleting a column from attribute table (adamu eloji)
> Message: 1
> Date: Wed, 27 Jul 2011 15:46:11 +0200
> From: percy langa <percylanga at gmail.com>
> Subject: Re: [Qgis-user] KML to GoogleEarth
> To: giovanni.manghi at gmail.com
> Cc: qgis-user at lists.osgeo.org, Walter Ludwick <wludwick at mac.com>
> Message-ID:
> <CAF3hcU58ySkP=LvgLOuMQbFtHo9tLPUZraSJCQ-f6ffrgicq8w at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Works for me >> Qgis 1.6 >> CRS: WGS84, EPSG:4326, 3452
> Also try saving to GPS exchange format, then open in google earth.
> Cheers!
> Percy
> On Wed, Jul 27, 2011 at 3:07 PM, Giovanni Manghi
> <giovanni.manghi at gmail.com>wrote:
>> Tha probably your shapefile is missing the .prj file, so when you load
>> it into QGIS it will probably be given the wrong CRS. Change it manually
>> then try again "save as..." and export in WGS84.
>> cheers
>> -- Giovanni --
>> On Wed, 2011-07-27 at 13:13 +0100, Walter Ludwick wrote:
>> > Hey, Saber: Thanks for the quick reply and explicit instructions.
>> > It was easy to do, i gave it a try -but still the same condition results,
>> alas (i.e. the KML saved, even using that WGS84 as CRS, is interpreted by
>> Google Earth as a set of polygons that covers the entire globe).
>> > I'm going to keep flailing, trying whatever other CRS seems likely, but
>> if there be any further ideas of things i might try, please don't hesitate
>> to suggest!
>> > /w
>> > On Jul 27, 2011, at 12:29 PM, Saber Razmjooei wrote:
>> > > The CRS you need is EPSG:4326
>> > > To find it easily, in search section change Authority to EPSG and
>> search
>> > > for ID.
>> > > Type 4326 and highlight the line from Coordinate Reference System:
>> > > WGS84 EPSG:4326 3452
>> > > Click OK.
>> > >> As a complete n00b to this list -also very new to QGIS and GIS in
>> general-
>> > >> i am having a problem that is i hope trivial to solve, for one of you
>> with
>> > >> more experience!
>> > >> Essentially: to take a (vector) layer from QGIS and "save as..." KML,
>> if i
>> > >> pass that dialog with defaults selected, i get a .KML file that
>> doesn't
>> > >> make much sense to Google Earth -that is to say, Google Earth can read
>> and
>> > >> will display the polygons, perhaps even in the right shape, tho i
>> cannot
>> > >> be sure about that, because they display as lines that pretty much
>> cover
>> > >> the entire globe!
>> > >> The one thing i can see that i think might be related to this problem
>> is,
>> > >> the CRS (Co-ordinate Reference System) parameter, which appears in the
>> > >> "Save as..." dialog box with "Original CRS" as the default
>> parameter...
>> > >> but then when i push the "browse" button, i am faced with an immense
>> > >> number of possibilities from which to choose, about which i have no
>> idea.
>> > >> Can anyone shed some light, and perhaps suggest a CRS that just might
>> > >> work? The geography i am trying to describe is in coastal Portugal, if
>> > >> that makes any difference... /w
>> > >> _______________________________________________
>> > >> Qgis-user at lists.osgeo.org
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/d7dd885f/attachment-0001.html
> Message: 2
> Date: Wed, 27 Jul 2011 14:50:37 +0100
> From: "Chris Green" <chris.green at ibstv.co.uk>
> Subject: RE: [Qgis-user] QGIS -> MySQL -> Mapserver ??
> To: "'Saber Razmjooei'" <razmjooeis at faunalia.co.uk>
> Message-ID: <039301cc4c64$31fc9860$95f5c920$@green at ibstv.co.uk>
> Content-Type: text/plain; charset="us-ascii"
> Saber
> Ogrinfo -summary on the MySQL table as saved by QGIS says:
> Layer name: geom_test
> Geometry: Unknown (any)
> Feature Count: 0
> Layer SRS WKT:
> (unknown)
> FID Column = id
> Geometry Column = Geometry
> Ogrinfo -summary on the table after running SELECT AsWKB(Geometry) says:
> Layer name: geom_test_converted
> Feature Count: 34
> Layer SRS WKT:
> (unknown)
> FID Column = id
> There is no projection in the layer, QGIS seems to assume that it is lat/lon
> and then reprojects it to 900913, which is what I am using overall.
> Maybe the lack of projection in the data is confusing OGR....but I'm not
> sure that if I apply projection to the layer via QGIS, it will get saved as
> part of the MySQL data??
> Chris
> -----Original Message-----
> From: Saber Razmjooei [mailto:razmjooeis at faunalia.co.uk]
> Sent: 27 July 2011 14:04
> To: Chris Green
> What does ogrinfo -al say about your geometry? Are those numbers located
> in the right place? Just to make sure your layer projection is set
> properly.
>> Hi Saber
>> I tried that, and the when the MySQL data is saved as an ESRI shapefile
>> the shapefile opens correctly.
>> I have been experimenting with converting the MySQL BLOB data. For example
>> if I try
>> SELECT AsText(Geometry) I get a line string which looks OK and could be
>> used to create a line feature in MapServer using PHP Mapscript. Then when
>> I try:
>> SELECT AsWKB(Geometry) I get a new set of BLOBs which can be recognised by
>> OGRinfo as features (progress!!!) but still not displayed by MapServer.
>> My conclusion is that QGIS is using some internal format to store MySQL
>> linestrings which is not properly understood by OGR.
>> Any idea where I could find out any more on this?
>> Chris
>> From: Saber [mailto:razmjooeis at faunalia.co.uk]
>> Sent: 27 July 2011 10:55
>> To: Chris Green
>> As a test, worth converting the mysql vector to shapefile to see if the
>> vector is shown properly.
>> Also checking webserver logs report for mapsever requests of the MySQL
>> vector might help.
>> Chris Green <chris.green at ibstv.co.uk> wrote:
>>>Hi Saber
>>>Thanks for the suggestion. When I run ogrinfo -formats I see that MySQL
>>> is
>>>included, so that is not the problem.
>>>It seems that the issue is about the way that I created and store the
>>> line
>>>data, because I have tried with some point data and I don't have this
>>>problem - I can create, save, and display points with QGIS and then both
>>> OGR
>>>and MapServer are OK. But with line data it is different.
>>>I can only assume that QGIS is sending the line data to MySQL in a format
>>>that QGIS recognises when the data is retrieved, but which is not
>>> recognised
>>>by OGR / MapServer.
>>>Going to PostGIS would have to be a last resort, I have a lot of effort
>>>invested in MySQL ..
>>>Chris
>>>Sent: 27 July 2011 09:35
>>>To: Chris Green
>>>Subject: Re: [Qgis-user] QGIS -> MySQL -> Mapserver ??
>>>Chris
>>>I presume your ogr can handle mysql if you can open it in QGIS. But to
>>>confirm could you run:
>>>ogrinfo --formats
>>>from terminal and check if you have
>>>-> "MSSQLSpatial" (read/write)
>>>Is your database large? Have you considered using PostGIS?
>>>Cheers
>>>Saber
>>>On 27/07/11 07:45, Chris Green wrote:
>>>Hi QGIS users
>>>I have a problem getting Mapserver to display vector line features which
>>> I
>>>created with QGIS and saved as spatial objects in MySQL...I asked for
>>> some
>>>advice on this from the Mapserver forum yesterday but had no responses,
>>>perhaps someone in this forum has some experience to offer?
>>>As explained in the question below, I can create line features in QGIS,
>>> save
>>>them in a MySQL table, and recall and display them with QGIS without any
>>>problem. But the same features do not appear to be recognised by OGRInfo
>>> or
>>>by Mapserver. The line features are saved as BLOB data in a MySQL MyISAM
>>>table in a column which is defined as type 'geometry'. MySQL can create a
>>>spatial index of these features.
>>>The table is accessed by QGIS as a database layer via the 'Add Vector
>>> Layer'
>>>dialogue. I am using QGIS 1.7.
>>>It's not really a QGIS problem, but I spent all day wrestling with this
>>>yesterday but have not solved it. Any suggestions?
>>>Chris
>>>I'm having some trouble with an OGR connection to a MySQL database. The
>>> data
>>>I'm trying to access was created using QGIS as a line layer and saved in
>>> a
>>>MySQL table as a BLOB in a geometry column. I can access and properly
>>>display this line data using QGIS, but not so far via Mapserver - nothing
>>> is
>>>drawn and I can't see any error.
>>>I am using Mapserver 6.0 and my mapfile is very similar to the example in
>>>theMapserver / MYSQL documentation:
>>>LAYER
>>> NAME "testLine"
>>> TYPE LINE
>>> STATUS DEFAULT
>>> CONNECTIONTYPE OGR
>>> CONNECTION "mysql:testDB,user=admin,password=password,port=3306"
>>> DATA "SELECT Geometry from testLine"
>>> CLASS
>>> STYLE
>>> COLOR 0 0 0
>>> WIDTH 2
>>> END # style
>>> END # class
>>>END # layer
>>>If I look at the MySQL table using OGRinfo I see the following:
>>>Layer name: testLine
>>>Feature Count: 0
>>>Layer SRS WKT:
>>>(unknown)
>>>FID Coumn = id
>>>The issue seems to be that OGRInfo and therefore MapServer does not
>>>recognise any features in the table, but QGIS using access to the same
>>> table
>>>finds and displays the features.
>>>Anyone have any ideas what I am doing wrong?
>>>Chris
> Message: 3
> Date: Wed, 27 Jul 2011 15:03:32 +0100
> From: "Saber Razmjooei" <razmjooeis at faunalia.co.uk>
> To: "Chris Green" <chris.green at ibstv.co.uk>
> Message-ID:
> <8f1479b5016f16ec694cce8d304c9e5e.squirrel at www.webmail.lutraconsulting.co.uk>
> Content-Type: text/plain;charset=iso-8859-1
> Chris
> Have you checked this:
> 18.4.2.1. Creating Geometry Values Using WKT Functions
> http://www.qijoo.com/FAPM/mysql/5.1/MySQL_51_en/ch18s04.html
> You can optionally use SRID in your query.
> I am a bit out of my depth now as I have never used mysql spatial.
> Hope that helps
> Saber
>> Saber
>> Feature Count: 0
>> Layer SRS WKT:
>> (unknown)
>> FID Column = id
>> Feature Count: 34
>> Layer SRS WKT:
>> (unknown)
>> FID Column = id
>> lat/lon
>> as
>> Chris
>> To: Chris Green
>> properly.
>>> Hi Saber
>>> example
>>> if I try
>>> when
>>> I try:
>>> by
>>> Chris
>>> To: Chris Green
>>> vector might help.
>>>>Hi Saber
>>>> is
>>>> line
>>>> OGR
>>>> format
>>>> recognised
>>>>by OGR / MapServer.
>>>>Chris
>>>>To: Chris Green
>>>>Chris
>>>>ogrinfo --formats
>>>>Cheers
>>>>Saber
>>>>Hi QGIS users
>>>> I
>>>> some
>>>> save
>>>> OGRInfo
>>>> or
>>>> MyISAM
>>>> a
>>>> Layer'
>>>>Chris
>>>> data
>>>> a
>>>> nothing
>>>> is
>>>> in
>>>>LAYER
>>>> NAME "testLine"
>>>> TYPE LINE
>>>> STATUS DEFAULT
>>>> CONNECTIONTYPE OGR
>>>> CLASS
>>>> STYLE
>>>> COLOR 0 0 0
>>>> WIDTH 2
>>>> END # style
>>>> END # class
>>>>END # layer
>>>>Feature Count: 0
>>>>Layer SRS WKT:
>>>>(unknown)
>>>>FID Coumn = id
>>>> table
>>>>Chris
> Message: 4
> Date: Wed, 27 Jul 2011 08:19:23 -0700 (PDT)
> From: adamu eloji <aeloji60 at yahoo.com>
> Subject: [Qgis-user] Deleting a column from attribute table
> To: qgis-user at lists.osgeo.org
> Message-ID:
> <1311779963.99219.YahooMailClassic at web114719.mail.gq1.yahoo.com>
> Dear All,
> As a novice in QGIS, i created a column on an attribute which i dont want any more, pls can any experience person tell me how to delete the column.
> Thanks
> El-Oji
> --- On Wed, 7/27/11, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
> From: qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org>
> Subject: Qgis-user Digest, Vol 65, Issue 61
> Date: Wednesday, July 27, 2011, 11:14 AM
> Today's Topics:
> 1. Re: object labels (Andreas Neumann)
> 3. RE: QGIS -> MySQL -> Mapserver ?? (Saber)
> 4. DTclassifier is released (Maxim Dubinin)
> Message: 1
> Date: Wed, 27 Jul 2011 11:00:01 +0200
> From: Andreas Neumann <a.neumann at carto.net>
> Subject: Re: [Qgis-user] object labels
> To: <qgis-user at lists.osgeo.org>
> Message-ID: <2634cc5e1e8f0d3a1c3ecba07210ba79 at carto.net>
> Content-Type: text/plain; charset=UTF-8; format=flowed
> Hi,
> Currently, you have to create a new column. I usually create a view in
> Postgis for this purpose.
> It is in on the wishlist that one can create a "virtual" column - not
> only for labeling, but also for map tips and perhaps symbolization.
> Until then you have to do it yourself.
> Andreas
> On Tue, 26 Jul 2011 22:51:34 +0200, Torsten Lange wrote:
>> Hi,
>> Is there a way just to print - lets say - the first four letters of a
>> objects
>> name? Or must I create a new row for that?
>> Thank you, Torsten
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Message: 2
> Date: Wed, 27 Jul 2011 10:00:27 +0100
> Message-ID: <02a401cc4c3b$a25fa3a0$e71eeae0$@green at ibstv.co.uk>
> Hi Saber
> Thanks for the suggestion. When I run ogrinfo -formats I see that MySQL is
> It seems that the issue is about the way that I created and store the line
> problem - I can create, save, and display points with QGIS and then both OGR
> that QGIS recognises when the data is retrieved, but which is not recognised
> by OGR / MapServer.
> Chris
> To: Chris Green
> Chris
> ogrinfo --formats
> Cheers
> Saber
> Hi QGIS users
> I have a problem getting Mapserver to display vector line features which I
> created with QGIS and saved as spatial objects in MySQL...I asked for some
> As explained in the question below, I can create line features in QGIS, save
> problem. But the same features do not appear to be recognised by OGRInfo or
> The table is accessed by QGIS as a database layer via the 'Add Vector Layer'
> Chris
> I'm having some trouble with an OGR connection to a MySQL database. The data
> I'm trying to access was created using QGIS as a line layer and saved in a
> display this line data using QGIS, but not so far via Mapserver - nothing is
> LAYER
> NAME "testLine"
> TYPE LINE
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CLASS
> STYLE
> COLOR 0 0 0
> WIDTH 2
> END # style
> END # class
> END # layer
> Feature Count: 0
> Layer SRS WKT:
> (unknown)
> FID Coumn = id
> recognise any features in the table, but QGIS using access to the same table
> Chris
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/414a5aee/attachment-0001.html
> Message: 3
> Date: Wed, 27 Jul 2011 10:55:20 +0100
> From: Saber <razmjooeis at faunalia.co.uk>
> To: Chris Green <chris.green at ibstv.co.uk>
> Message-ID: <05cdp715sy1xrat8ywciguee.1311760349356 at email.android.com>
> Content-Type: text/plain; charset=utf-8
> As a test, worth converting the mysql vector to shapefile to see if the vector is shown properly.
> Also checking webserver logs report for mapsever requests of the MySQL vector might help.
>>Hi Saber
>>by OGR / MapServer.
>>Chris
>>To: Chris Green
>>Chris
>>ogrinfo --formats
>>Cheers
>>Saber
>>Hi QGIS users
>>Chris
>>LAYER
>> NAME "testLine"
>> TYPE LINE
>> STATUS DEFAULT
>> CONNECTIONTYPE OGR
>> CLASS
>> STYLE
>> COLOR 0 0 0
>> WIDTH 2
>> END # style
>> END # class
>>END # layer
>>Feature Count: 0
>>Layer SRS WKT:
>>(unknown)
>>FID Coumn = id
>>Chris
> Message: 4
> Date: Wed, 27 Jul 2011 14:09:39 +0400
> From: Maxim Dubinin <sim at gis-lab.info>
> Subject: [Qgis-user] DTclassifier is released
> To: qgis-developer at lists.osgeo.org
> Message-ID: <77239752.20110727140939 at gis-lab.info>
> Content-Type: text/plain; charset=us-ascii
> Hi all,
> To follow up on our demonstration in Lisbon.
> We are happy to release our new plugin for streamlined remote sensing
> data classification in QGIS [0]. Initially the plugin was
> developed to provide easy to use tool to monitor forest cover
> change, but it can be used to classify any type of targets.
> Main features:
> - all-in-one, with this plugin only QGIS is needed for all steps of
> classification;
> - decision trees, the plugin is using computer vision library OpenCV to
> implement modern classification algorithm typically not available in
> other software packages (both OS and proprietory);
> - performance, another nice feature of OpenCV is that it is
> very fast;
> - multiple input rasters and multiple training layers;
> Description, examples and sample data:
> EN: http://gis-lab.info/qa/dtclassifier-eng.html
> RU: http://gis-lab.info/qa/dtclassifier.html
> Right now the windows binaries and source code are available.
> Maxim
> [0] http://www.nextgis.ru/projects/dtclassifier
> End of Qgis-user Digest, Vol 65, Issue 61
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/2d5a5976/attachment.html
> End of Qgis-user Digest, Vol 65, Issue 64
