[Qgis-user] Can not remote access PostGIS layers
Matt Boyd mattslists at gmail.com
Wed Jul 27 21:43:43 PDT 2011
It could be a couple of things.
the default installation of Postgresql in a few distributions doesn't
allow remote access. You may need to edit the configuration files to
allow this. Run nmap against the host to see if the postgresql port is
visible.
You haven't given much information about how your system is set up but
try accessing the host by ip address to see if it's an error resolving
the hostname.
regards
Matt
On Thu, Jul 28, 2011 at 6:25 AM, Nomeneta Saili <nome.saili at gmail.com> wrote:
> Hi people,
> I have set up PostGIS on my server and i am able access the GIS layers
> posted on it using the hostname : localhost on the server itself.
> However when i try to access the PostGIS layer from another computer
> using the hostname : GIS-SERVER (Server name on our network) it can't
> access. A popup menu ask for credentials with an error message can not
> translate host name.
> Any help would be much appreciated.
> Thanks,
> Nome
> On Wed, Jul 27, 2011 at 9:24 AM,  <qgis-user-request at lists.osgeo.org> wrote:
>> Send Qgis-user mailing list submissions to
>>        qgis-user at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>>        http://lists.osgeo.org/mailman/listinfo/qgis-user
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>        qgis-user-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of Qgis-user digest..."
>> Today's Topics:
>>   1. Re: KML to GoogleEarth (percy langa)
>>   2. RE: QGIS -> MySQL -> Mapserver ?? (Chris Green)
>>   3. RE: QGIS -> MySQL -> Mapserver ?? (Saber Razmjooei)
>>   4. Deleting a column from attribute table  (adamu eloji)
>> Message: 1
>> Date: Wed, 27 Jul 2011 15:46:11 +0200
>> From: percy langa <percylanga at gmail.com>
>> Subject: Re: [Qgis-user] KML to GoogleEarth
>> To: giovanni.manghi at gmail.com
>> Cc: qgis-user at lists.osgeo.org, Walter Ludwick <wludwick at mac.com>
>> Message-ID:
>>        <CAF3hcU58ySkP=LvgLOuMQbFtHo9tLPUZraSJCQ-f6ffrgicq8w at mail.gmail.com>
>> Content-Type: text/plain; charset="iso-8859-1"
>> Works for me >> Qgis 1.6 >> CRS: WGS84, EPSG:4326, 3452
>> Also try saving to GPS exchange format, then open in google earth.
>> Cheers!
>> Percy
>> On Wed, Jul 27, 2011 at 3:07 PM, Giovanni Manghi
>> <giovanni.manghi at gmail.com>wrote:
>>> Tha  probably your shapefile is missing the .prj file, so when you load
>>> it into QGIS it will probably be given the wrong CRS. Change it manually
>>> then try again "save as..." and export in WGS84.
>>> cheers
>>> -- Giovanni --
>>> On Wed, 2011-07-27 at 13:13 +0100, Walter Ludwick wrote:
>>> > Hey, Saber: Thanks for the quick reply and explicit instructions.
>>> > It was easy to do, i gave it a try -but still the same condition results,
>>> alas (i.e. the KML saved, even using that WGS84 as CRS, is interpreted by
>>> Google Earth as a set of polygons that covers the entire globe).
>>> > I'm going to keep flailing, trying whatever other CRS seems likely, but
>>> if there be any further ideas of things i might try, please don't hesitate
>>> to suggest!
>>> > /w
>>> > On Jul 27, 2011, at 12:29 PM, Saber Razmjooei wrote:
>>> > > The CRS you need is EPSG:4326
>>> > > To find it easily, in search section change Authority to EPSG and
>>> search
>>> > > for ID.
>>> > > Type 4326 and highlight the line from Coordinate Reference System:
>>> > > WGS84   EPSG:4326     3452
>>> > > Click OK.
>>> > >> As a complete n00b to this list -also very new to QGIS and GIS in
>>> general-
>>> > >> i am having a problem that is i hope trivial to solve, for one of you
>>> with
>>> > >> more experience!
>>> > >> Essentially: to take a (vector) layer from QGIS and "save as..." KML,
>>> if i
>>> > >> pass that dialog with defaults selected, i get a .KML file that
>>> doesn't
>>> > >> make much sense to Google Earth -that is to say, Google Earth can read
>>> and
>>> > >> will display the polygons, perhaps even in the right shape, tho i
>>> cannot
>>> > >> be sure about that, because they display as lines that pretty much
>>> cover
>>> > >> the entire globe!
>>> > >> The one thing i can see that i think might be related to this problem
>>> is,
>>> > >> the CRS (Co-ordinate Reference System) parameter, which appears in the
>>> > >> "Save as..." dialog box with "Original CRS" as the default
>>> parameter...
>>> > >> but then when i push the "browse" button, i am faced with an immense
>>> > >> number of possibilities from which to choose, about which i have no
>>> idea.
>>> > >> Can anyone shed some light, and perhaps suggest a CRS that just might
>>> > >> work? The geography i am trying to describe is in coastal Portugal, if
>>> > >> that makes any difference...       /w
>>> > >> _______________________________________________
>>> > >> Qgis-user at lists.osgeo.org
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/d7dd885f/attachment-0001.html
>> Message: 2
>> Date: Wed, 27 Jul 2011 14:50:37 +0100
>> From: "Chris Green" <chris.green at ibstv.co.uk>
>> Subject: RE: [Qgis-user] QGIS -> MySQL -> Mapserver ??
>> To: "'Saber Razmjooei'" <razmjooeis at faunalia.co.uk>
>> Message-ID: <039301cc4c64$31fc9860$95f5c920$@green at ibstv.co.uk>
>> Content-Type: text/plain;       charset="us-ascii"
>> Saber
>> Ogrinfo -summary on the MySQL table as saved by QGIS says:
>> Layer name:      geom_test
>> Geometry: Unknown (any)
>> Feature Count: 0
>> Layer SRS WKT:
>> (unknown)
>> FID Column = id
>> Geometry Column = Geometry
>> Ogrinfo -summary on the table after running SELECT AsWKB(Geometry) says:
>> Layer name:      geom_test_converted
>> Feature Count: 34
>> Layer SRS WKT:
>> (unknown)
>> FID Column = id
>> There is no projection in the layer, QGIS seems to assume that it is lat/lon
>> and then reprojects it to 900913, which is what I am using overall.
>> Maybe the lack of projection in the data is confusing OGR....but I'm not
>> sure that if I apply projection to the layer via QGIS, it will get saved as
>> part of the MySQL data??
>> Chris
>> -----Original Message-----
>> From: Saber Razmjooei [mailto:razmjooeis at faunalia.co.uk]
>> Sent: 27 July 2011 14:04
>> To: Chris Green
>> What does ogrinfo -al say about your geometry? Are those numbers located
>> in the right place? Just to make sure your layer projection is set
>> properly.
>>> Hi Saber
>>> I tried that, and the when the MySQL data is saved as an ESRI shapefile
>>> the shapefile opens correctly.
>>> I have been experimenting with converting the MySQL BLOB data. For example
>>> if I try
>>> SELECT AsText(Geometry) I get a line string which looks OK and could be
>>> used to create a line feature in MapServer using PHP Mapscript. Then when
>>> I try:
>>> SELECT AsWKB(Geometry) I get a new set of BLOBs which can be recognised by
>>> OGRinfo as features (progress!!!) but still not displayed by MapServer.
>>> My conclusion is that QGIS is using some internal format to store MySQL
>>> linestrings which is not properly understood by OGR.
>>> Any idea where I could find out any more on this?
>>> Chris
>>> From: Saber [mailto:razmjooeis at faunalia.co.uk]
>>> Sent: 27 July 2011 10:55
>>> To: Chris Green
>>> As a test, worth converting the mysql vector to shapefile to see if the
>>> vector is shown properly.
>>> Also checking webserver logs report for mapsever requests of the MySQL
>>> vector might help.
>>> Chris Green <chris.green at ibstv.co.uk> wrote:
>>>>Hi Saber
>>>>Thanks for the suggestion. When I run ogrinfo -formats I see that MySQL
>>>> is
>>>>included, so that is not the problem.
>>>>It seems that the issue is about the way that I created and store the
>>>> line
>>>>data, because I have tried with some point data and I don't have this
>>>>problem - I can create, save, and display points with QGIS and then both
>>>> OGR
>>>>and MapServer are OK. But with line data it is different.
>>>>I can only assume that QGIS is sending the line data to MySQL in a format
>>>>that QGIS recognises when the data is retrieved, but which is not
>>>> recognised
>>>>by OGR / MapServer.
>>>>Going to PostGIS would have to be a last resort, I have a lot of effort
>>>>invested in MySQL ..
>>>>Chris
>>>>Sent: 27 July 2011 09:35
>>>>To: Chris Green
>>>>Subject: Re: [Qgis-user] QGIS -> MySQL -> Mapserver ??
>>>>Chris
>>>>I presume your ogr can handle mysql if you can open it in QGIS. But to
>>>>confirm could you run:
>>>>ogrinfo --formats
>>>>from terminal and check if you have
>>>>-> "MSSQLSpatial" (read/write)
>>>>Is your database large? Have you considered using PostGIS?
>>>>Cheers
>>>>Saber
>>>>On 27/07/11 07:45, Chris Green wrote:
>>>>Hi QGIS users
>>>>I have a problem getting Mapserver to display vector line features which
>>>> I
>>>>created with QGIS and saved as spatial objects in MySQL...I asked for
>>>> some
>>>>advice on this from the Mapserver forum yesterday but had no responses,
>>>>perhaps someone in this forum has some experience to offer?
>>>>As explained in the question below, I can create line features in QGIS,
>>>> save
>>>>them in a MySQL table, and recall and display them with QGIS without any
>>>>problem.  But the same features do not appear to be recognised by OGRInfo
>>>> or
>>>>by Mapserver. The line features are saved as BLOB data in a MySQL  MyISAM
>>>>table in a column which is defined as type 'geometry'. MySQL can create a
>>>>spatial index of these features.
>>>>The table is accessed by QGIS as a database layer via the 'Add Vector
>>>> Layer'
>>>>dialogue. I am using QGIS 1.7.
>>>>It's not really a QGIS problem, but I spent all day wrestling with this
>>>>yesterday but have not solved it.  Any suggestions?
>>>>Chris
>>>>I'm having some trouble with an OGR connection to a MySQL database. The
>>>> data
>>>>I'm trying to access was created using QGIS as a line layer and saved in
>>>> a
>>>>MySQL table as a BLOB in a geometry column. I can access and properly
>>>>display this line data using QGIS, but not so far via Mapserver - nothing
>>>> is
>>>>drawn and I can't see any error.
>>>>I am using Mapserver 6.0 and my mapfile is very similar to the example in
>>>>theMapserver / MYSQL  documentation:
>>>>LAYER
>>>>       NAME "testLine"
>>>>       TYPE   LINE
>>>>       STATUS  DEFAULT
>>>>       CONNECTIONTYPE  OGR
>>>>       CONNECTION  "mysql:testDB,user=admin,password=password,port=3306"
>>>>       DATA "SELECT Geometry from testLine"
>>>>       CLASS
>>>>              STYLE
>>>>                     COLOR  0 0 0
>>>>                     WIDTH  2
>>>>              END # style
>>>>       END # class
>>>>END # layer
>>>>If I look at the MySQL table using OGRinfo I see the following:
>>>>Layer name: testLine
>>>>Feature Count: 0
>>>>Layer SRS WKT:
>>>>(unknown)
>>>>FID Coumn = id
>>>>The issue seems to be that OGRInfo and therefore MapServer does not
>>>>recognise any features in the table, but QGIS using access to the same
>>>> table
>>>>finds and displays the features.
>>>>Anyone have any ideas what I am doing wrong?
>>>>Chris
>> Message: 3
>> Date: Wed, 27 Jul 2011 15:03:32 +0100
>> From: "Saber Razmjooei" <razmjooeis at faunalia.co.uk>
>> To: "Chris Green" <chris.green at ibstv.co.uk>
>> Message-ID:
>>        <8f1479b5016f16ec694cce8d304c9e5e.squirrel at www.webmail.lutraconsulting.co.uk>
>> Content-Type: text/plain;charset=iso-8859-1
>> Chris
>> Have you checked this:
>> 18.4.2.1. Creating Geometry Values Using WKT Functions
>> http://www.qijoo.com/FAPM/mysql/5.1/MySQL_51_en/ch18s04.html
>> You can optionally use SRID in your query.
>> I am a bit out of my depth now as I have never used mysql spatial.
>> Hope that helps
>> Saber
>>> Saber
>>> Feature Count: 0
>>> Layer SRS WKT:
>>> (unknown)
>>> FID Column = id
>>> Feature Count: 34
>>> Layer SRS WKT:
>>> (unknown)
>>> FID Column = id
>>> lat/lon
>>> as
>>> Chris
>>> To: Chris Green
>>> properly.
>>>> Hi Saber
>>>> example
>>>> if I try
>>>> when
>>>> I try:
>>>> by
>>>> Chris
>>>> To: Chris Green
>>>> vector might help.
>>>>>Hi Saber
>>>>> is
>>>>> line
>>>>> OGR
>>>>> format
>>>>> recognised
>>>>>by OGR / MapServer.
>>>>>Chris
>>>>>To: Chris Green
>>>>>Chris
>>>>>ogrinfo --formats
>>>>>Cheers
>>>>>Saber
>>>>>Hi QGIS users
>>>>> I
>>>>> some
>>>>> save
>>>>> OGRInfo
>>>>> or
>>>>> MyISAM
>>>>> a
>>>>> Layer'
>>>>>Chris
>>>>> data
>>>>> a
>>>>> nothing
>>>>> is
>>>>> in
>>>>>LAYER
>>>>>       NAME "testLine"
>>>>>       TYPE   LINE
>>>>>       STATUS  DEFAULT
>>>>>       CONNECTIONTYPE  OGR
>>>>>       CLASS
>>>>>              STYLE
>>>>>                     COLOR  0 0 0
>>>>>                     WIDTH  2
>>>>>              END # style
>>>>>       END # class
>>>>>END # layer
>>>>>Feature Count: 0
>>>>>Layer SRS WKT:
>>>>>(unknown)
>>>>>FID Coumn = id
>>>>> table
>>>>>Chris
>> Message: 4
>> Date: Wed, 27 Jul 2011 08:19:23 -0700 (PDT)
>> From: adamu eloji <aeloji60 at yahoo.com>
>> Subject: [Qgis-user] Deleting a column from attribute table
>> To: qgis-user at lists.osgeo.org
>> Message-ID:
>>        <1311779963.99219.YahooMailClassic at web114719.mail.gq1.yahoo.com>
>> Dear All,
>>             As a novice in QGIS, i created a column on an attribute which i dont want any more, pls can any experience person tell me how to delete the column.
>> Thanks
>> El-Oji
>> --- On Wed, 7/27/11, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
>> From: qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org>
>> Subject: Qgis-user Digest, Vol 65, Issue 61
>> Date: Wednesday, July 27, 2011, 11:14 AM
>> Today's Topics:
>>    1. Re: object labels (Andreas Neumann)
>>    3. RE: QGIS -> MySQL -> Mapserver ?? (Saber)
>>    4. DTclassifier is released (Maxim Dubinin)
>> Message: 1
>> Date: Wed, 27 Jul 2011 11:00:01 +0200
>> From: Andreas Neumann <a.neumann at carto.net>
>> Subject: Re: [Qgis-user] object labels
>> To: <qgis-user at lists.osgeo.org>
>> Message-ID: <2634cc5e1e8f0d3a1c3ecba07210ba79 at carto.net>
>> Content-Type: text/plain; charset=UTF-8; format=flowed
>> Hi,
>> Currently, you have to create a new column. I usually create a view in
>> Postgis for this purpose.
>> It is in on the wishlist that one can create a "virtual" column - not
>> only for labeling, but also for map tips and perhaps symbolization.
>> Until then you have to do it yourself.
>> Andreas
>> On Tue, 26 Jul 2011 22:51:34 +0200, Torsten Lange wrote:
>>> Hi,
>>> Is there a way just to print - lets say - the first four letters of a
>>> objects
>>> name? Or must I create a new row for that?
>>> Thank you, Torsten
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> Message: 2
>> Date: Wed, 27 Jul 2011 10:00:27 +0100
>> Message-ID: <02a401cc4c3b$a25fa3a0$e71eeae0$@green at ibstv.co.uk>
>> Hi Saber
>> Thanks for the suggestion. When I run ogrinfo -formats I see that MySQL is
>> It seems that the issue is about the way that I created and store the line
>> problem - I can create, save, and display points with QGIS and then both OGR
>> that QGIS recognises when the data is retrieved, but which is not recognised
>> by OGR / MapServer.
>> Chris
>> To: Chris Green
>> Chris
>> ogrinfo --formats
>> Cheers
>> Saber
>> Hi QGIS users
>> I have a problem getting Mapserver to display vector line features which I
>> created with QGIS and saved as spatial objects in MySQL...I asked for some
>> As explained in the question below, I can create line features in QGIS, save
>> problem.  But the same features do not appear to be recognised by OGRInfo or
>> The table is accessed by QGIS as a database layer via the 'Add Vector Layer'
>> Chris
>> I'm having some trouble with an OGR connection to a MySQL database. The data
>> I'm trying to access was created using QGIS as a line layer and saved in a
>> display this line data using QGIS, but not so far via Mapserver - nothing is
>> LAYER
>>        NAME "testLine"
>>        TYPE   LINE
>>        STATUS  DEFAULT
>>        CONNECTIONTYPE  OGR
>>        CLASS
>>               STYLE
>>                      COLOR  0 0 0
>>                      WIDTH  2
>>               END # style
>>        END # class
>> END # layer
>> Feature Count: 0
>> Layer SRS WKT:
>> (unknown)
>> FID Coumn = id
>> recognise any features in the table, but QGIS using access to the same table
>> Chris
>> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/414a5aee/attachment-0001.html
>> Message: 3
>> Date: Wed, 27 Jul 2011 10:55:20 +0100
>> From: Saber <razmjooeis at faunalia.co.uk>
>> To: Chris Green <chris.green at ibstv.co.uk>
>> Message-ID: <05cdp715sy1xrat8ywciguee.1311760349356 at email.android.com>
>> Content-Type: text/plain; charset=utf-8
>> As a test, worth converting the mysql vector to shapefile to see if the vector is shown properly.
>> Also checking webserver logs report for mapsever requests of the MySQL vector might help.
>>>Hi Saber
>>>by OGR / MapServer.
>>>Chris
>>>To: Chris Green
>>>Chris
>>>ogrinfo --formats
>>>Cheers
>>>Saber
>>>Hi QGIS users
>>>Chris
>>>LAYER
>>>       NAME "testLine"
>>>       TYPE   LINE
>>>       STATUS  DEFAULT
>>>       CONNECTIONTYPE  OGR
>>>       CLASS
>>>              STYLE
>>>                     COLOR  0 0 0
>>>                     WIDTH  2
>>>              END # style
>>>       END # class
>>>END # layer
>>>Feature Count: 0
>>>Layer SRS WKT:
>>>(unknown)
>>>FID Coumn = id
>>>Chris
>> Message: 4
>> Date: Wed, 27 Jul 2011 14:09:39 +0400
>> From: Maxim Dubinin <sim at gis-lab.info>
>> Subject: [Qgis-user] DTclassifier is released
>> To: qgis-developer at lists.osgeo.org
>> Message-ID: <77239752.20110727140939 at gis-lab.info>
>> Content-Type: text/plain; charset=us-ascii
>> Hi all,
>> To follow up on our demonstration in Lisbon.
>> We  are happy to release our new plugin for streamlined remote sensing
>> data    classification    in    QGIS    [0].  Initially the plugin was
>> developed   to   provide   easy  to  use  tool to monitor forest cover
>> change, but it can be used to classify any type of targets.
>> Main features:
>> -  all-in-one, with this plugin only QGIS is needed for all steps of
>> classification;
>> -  decision trees,  the  plugin  is  using  computer  vision library OpenCV to
>> implement  modern  classification algorithm typically not available in
>> other software packages (both OS and proprietory);
>> -   performance,   another   nice  feature  of  OpenCV  is  that it is
>> very fast;
>> - multiple input rasters and multiple training layers;
>> Description, examples and sample data:
>> EN: http://gis-lab.info/qa/dtclassifier-eng.html
>> RU: http://gis-lab.info/qa/dtclassifier.html
>> Right now the windows binaries and source code are available.
>> Maxim
>> [0] http://www.nextgis.ru/projects/dtclassifier
>> End of Qgis-user Digest, Vol 65, Issue 61
>> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/2d5a5976/attachment.html
>> End of Qgis-user Digest, Vol 65, Issue 64
