[Qgis-user] Can not remote access PostGIS layers
Andreas Neumann a.neumann at carto.net
Thu Jul 28 00:46:09 PDT 2011
 I am also pretty sure that your problems have nothing to do with QGIS,
 but with your PostgreSQL server configuration.
 Make sure you can access your PostgreSQL server from a different
 machine with psql and pgadmin3. Once this works, it should also work
 with QGIS.
 Look at the postgresql.conf and the pg_hba.conf to enable remote
 access. PostgreSQL has excellent documentation on how to configure for
 remote access.
 Andreas
 On Thu, 28 Jul 2011 14:43:43 +1000, Matt Boyd wrote:
> It could be a couple of things.
> the default installation of Postgresql in a few distributions doesn't
> allow remote access. You may need to edit the configuration files to
> allow this. Run nmap against the host to see if the postgresql port
> is
> visible.
> You haven't given much information about how your system is set up
> but
> try accessing the host by ip address to see if it's an error
> resolving
> the hostname.
> regards
> Matt
> On Thu, Jul 28, 2011 at 6:25 AM, Nomeneta Saili
> <nome.saili at gmail.com> wrote:
>> Hi people,
>> I have set up PostGIS on my server and i am able access the GIS
>> layers
>> posted on it using the hostname : localhost on the server itself.
>> However when i try to access the PostGIS layer from another computer
>> using the hostname : GIS-SERVER (Server name on our network) it
>> can't
>> access. A popup menu ask for credentials with an error message can
>> not
>> translate host name.
>> Any help would be much appreciated.
>> Thanks,
>> Nome
>> On Wed, Jul 27, 2011 at 9:24 AM,
>>  <qgis-user-request at lists.osgeo.org> wrote:
>>> Send Qgis-user mailing list submissions to
>>>        qgis-user at lists.osgeo.org
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>        http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>>        qgis-user-owner at lists.osgeo.org
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of Qgis-user digest..."
>>> Today's Topics:
>>>   1. Re: KML to GoogleEarth (percy langa)
>>>   2. RE: QGIS -> MySQL -> Mapserver ?? (Chris Green)
>>>   3. RE: QGIS -> MySQL -> Mapserver ?? (Saber Razmjooei)
>>>   4. Deleting a column from attribute table  (adamu eloji)
>>> Message: 1
>>> Date: Wed, 27 Jul 2011 15:46:11 +0200
>>> From: percy langa <percylanga at gmail.com>
>>> Subject: Re: [Qgis-user] KML to GoogleEarth
>>> To: giovanni.manghi at gmail.com
>>> Cc: qgis-user at lists.osgeo.org, Walter Ludwick <wludwick at mac.com>
>>> Message-ID:
>>>  <CAF3hcU58ySkP=LvgLOuMQbFtHo9tLPUZraSJCQ-f6ffrgicq8w at mail.gmail.com>
>>> Content-Type: text/plain; charset="iso-8859-1"
>>> Works for me >> Qgis 1.6 >> CRS: WGS84, EPSG:4326, 3452
>>> Also try saving to GPS exchange format, then open in google earth.
>>> Cheers!
>>> Percy
>>> On Wed, Jul 27, 2011 at 3:07 PM, Giovanni Manghi
>>> <giovanni.manghi at gmail.com>wrote:
>>>> Tha  probably your shapefile is missing the .prj file, so when you
>>>> load
>>>> it into QGIS it will probably be given the wrong CRS. Change it
>>>> manually
>>>> then try again "save as..." and export in WGS84.
>>>> cheers
>>>> -- Giovanni --
>>>> On Wed, 2011-07-27 at 13:13 +0100, Walter Ludwick wrote:
>>>> > Hey, Saber: Thanks for the quick reply and explicit
>>>> instructions.
>>>> > It was easy to do, i gave it a try -but still the same condition
>>>> results,
>>>> alas (i.e. the KML saved, even using that WGS84 as CRS, is
>>>> interpreted by
>>>> Google Earth as a set of polygons that covers the entire globe).
>>>> > I'm going to keep flailing, trying whatever other CRS seems
>>>> likely, but
>>>> if there be any further ideas of things i might try, please don't
>>>> hesitate
>>>> to suggest!
>>>> > /w
>>>> > On Jul 27, 2011, at 12:29 PM, Saber Razmjooei wrote:
>>>> > > The CRS you need is EPSG:4326
>>>> > > To find it easily, in search section change Authority to EPSG
>>>> and
>>>> search
>>>> > > for ID.
>>>> > > Type 4326 and highlight the line from Coordinate Reference
>>>> System:
>>>> > > WGS84   EPSG:4326     3452
>>>> > > Click OK.
>>>> > >> As a complete n00b to this list -also very new to QGIS and
>>>> GIS in
>>>> general-
>>>> > >> i am having a problem that is i hope trivial to solve, for
>>>> one of you
>>>> with
>>>> > >> more experience!
>>>> > >> Essentially: to take a (vector) layer from QGIS and "save
>>>> as..." KML,
>>>> if i
>>>> > >> pass that dialog with defaults selected, i get a .KML file
>>>> that
>>>> doesn't
>>>> > >> make much sense to Google Earth -that is to say, Google Earth
>>>> can read
>>>> and
>>>> > >> will display the polygons, perhaps even in the right shape,
>>>> tho i
>>>> cannot
>>>> > >> be sure about that, because they display as lines that pretty
>>>> much
>>>> cover
>>>> > >> the entire globe!
>>>> > >> The one thing i can see that i think might be related to this
>>>> problem
>>>> is,
>>>> > >> the CRS (Co-ordinate Reference System) parameter, which
>>>> appears in the
>>>> > >> "Save as..." dialog box with "Original CRS" as the default
>>>> parameter...
>>>> > >> but then when i push the "browse" button, i am faced with an
>>>> immense
>>>> > >> number of possibilities from which to choose, about which i
>>>> have no
>>>> idea.
>>>> > >> Can anyone shed some light, and perhaps suggest a CRS that
>>>> just might
>>>> > >> work? The geography i am trying to describe is in coastal
>>>> Portugal, if
>>>> > >> that makes any difference...       /w
>>>> > >> _______________________________________________
>>>> > >> Qgis-user at lists.osgeo.org
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL:
>>> http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/d7dd885f/attachment-0001.html
>>> Message: 2
>>> Date: Wed, 27 Jul 2011 14:50:37 +0100
>>> From: "Chris Green" <chris.green at ibstv.co.uk>
>>> Subject: RE: [Qgis-user] QGIS -> MySQL -> Mapserver ??
>>> To: "'Saber Razmjooei'" <razmjooeis at faunalia.co.uk>
>>> Message-ID: <039301cc4c64$31fc9860$95f5c920$@green at ibstv.co.uk>
>>> Content-Type: text/plain;       charset="us-ascii"
>>> Saber
>>> Ogrinfo -summary on the MySQL table as saved by QGIS says:
>>> Layer name:      geom_test
>>> Geometry: Unknown (any)
>>> Feature Count: 0
>>> Layer SRS WKT:
>>> (unknown)
>>> FID Column = id
>>> Geometry Column = Geometry
>>> Ogrinfo -summary on the table after running SELECT AsWKB(Geometry)
>>> says:
>>> Layer name:      geom_test_converted
>>> Feature Count: 34
>>> Layer SRS WKT:
>>> (unknown)
>>> FID Column = id
>>> There is no projection in the layer, QGIS seems to assume that it
>>> is lat/lon
>>> and then reprojects it to 900913, which is what I am using overall.
>>> Maybe the lack of projection in the data is confusing OGR....but
>>> I'm not
>>> sure that if I apply projection to the layer via QGIS, it will get
>>> saved as
>>> part of the MySQL data??
>>> Chris
>>> -----Original Message-----
>>> From: Saber Razmjooei [mailto:razmjooeis at faunalia.co.uk]
>>> Sent: 27 July 2011 14:04
>>> To: Chris Green
>>> What does ogrinfo -al say about your geometry? Are those numbers
>>> located
>>> in the right place? Just to make sure your layer projection is set
>>> properly.
>>>> Hi Saber
>>>> I tried that, and the when the MySQL data is saved as an ESRI
>>>> shapefile
>>>> the shapefile opens correctly.
>>>> I have been experimenting with converting the MySQL BLOB data. For
>>>> example
>>>> if I try
>>>> SELECT AsText(Geometry) I get a line string which looks OK and
>>>> could be
>>>> used to create a line feature in MapServer using PHP Mapscript.
>>>> Then when
>>>> I try:
>>>> SELECT AsWKB(Geometry) I get a new set of BLOBs which can be
>>>> recognised by
>>>> OGRinfo as features (progress!!!) but still not displayed by
>>>> MapServer.
>>>> My conclusion is that QGIS is using some internal format to store
>>>> MySQL
>>>> linestrings which is not properly understood by OGR.
>>>> Any idea where I could find out any more on this?
>>>> Chris
>>>> From: Saber [mailto:razmjooeis at faunalia.co.uk]
>>>> Sent: 27 July 2011 10:55
>>>> To: Chris Green
>>>> As a test, worth converting the mysql vector to shapefile to see
>>>> if the
>>>> vector is shown properly.
>>>> Also checking webserver logs report for mapsever requests of the
>>>> MySQL
>>>> vector might help.
>>>> Chris Green <chris.green at ibstv.co.uk> wrote:
>>>>>Hi Saber
>>>>>Thanks for the suggestion. When I run ogrinfo -formats I see that
>>>>> MySQL
>>>>> is
>>>>>included, so that is not the problem.
>>>>>It seems that the issue is about the way that I created and store
>>>>> the
>>>>> line
>>>>>data, because I have tried with some point data and I don't have
>>>>> this
>>>>>problem - I can create, save, and display points with QGIS and
>>>>> then both
>>>>> OGR
>>>>>and MapServer are OK. But with line data it is different.
>>>>>I can only assume that QGIS is sending the line data to MySQL in a
>>>>> format
>>>>>that QGIS recognises when the data is retrieved, but which is not
>>>>> recognised
>>>>>by OGR / MapServer.
>>>>>Going to PostGIS would have to be a last resort, I have a lot of
>>>>> effort
>>>>>invested in MySQL ..
>>>>>Chris
>>>>>Sent: 27 July 2011 09:35
>>>>>To: Chris Green
>>>>>Subject: Re: [Qgis-user] QGIS -> MySQL -> Mapserver ??
>>>>>Chris
>>>>>I presume your ogr can handle mysql if you can open it in QGIS.
>>>>> But to
>>>>>confirm could you run:
>>>>>ogrinfo --formats
>>>>>from terminal and check if you have
>>>>>-> "MSSQLSpatial" (read/write)
>>>>>Is your database large? Have you considered using PostGIS?
>>>>>Cheers
>>>>>Saber
>>>>>On 27/07/11 07:45, Chris Green wrote:
>>>>>Hi QGIS users
>>>>>I have a problem getting Mapserver to display vector line features
>>>>> which
>>>>> I
>>>>>created with QGIS and saved as spatial objects in MySQL...I asked
>>>>> for
>>>>> some
>>>>>advice on this from the Mapserver forum yesterday but had no
>>>>> responses,
>>>>>perhaps someone in this forum has some experience to offer?
>>>>>As explained in the question below, I can create line features in
>>>>> QGIS,
>>>>> save
>>>>>them in a MySQL table, and recall and display them with QGIS
>>>>> without any
>>>>>problem.  But the same features do not appear to be recognised by
>>>>> OGRInfo
>>>>> or
>>>>>by Mapserver. The line features are saved as BLOB data in a MySQL
>>>>>  MyISAM
>>>>>table in a column which is defined as type 'geometry'. MySQL can
>>>>> create a
>>>>>spatial index of these features.
>>>>>The table is accessed by QGIS as a database layer via the 'Add
>>>>> Vector
>>>>> Layer'
>>>>>dialogue. I am using QGIS 1.7.
>>>>>It's not really a QGIS problem, but I spent all day wrestling with
>>>>> this
>>>>>yesterday but have not solved it.  Any suggestions?
>>>>>Chris
>>>>>I'm having some trouble with an OGR connection to a MySQL
>>>>> database. The
>>>>> data
>>>>>I'm trying to access was created using QGIS as a line layer and
>>>>> saved in
>>>>> a
>>>>>MySQL table as a BLOB in a geometry column. I can access and
>>>>> properly
>>>>>display this line data using QGIS, but not so far via Mapserver -
>>>>> nothing
>>>>> is
>>>>>drawn and I can't see any error.
>>>>>I am using Mapserver 6.0 and my mapfile is very similar to the
>>>>> example in
>>>>>theMapserver / MYSQL  documentation:
>>>>>LAYER
>>>>>       NAME "testLine"
>>>>>       TYPE   LINE
>>>>>       STATUS  DEFAULT
>>>>>       CONNECTIONTYPE  OGR
>>>>>       CONNECTION
>>>>>  "mysql:testDB,user=admin,password=password,port=3306"
>>>>>       DATA "SELECT Geometry from testLine"
>>>>>       CLASS
>>>>>              STYLE
>>>>>                     COLOR  0 0 0
>>>>>                     WIDTH  2
>>>>>              END # style
>>>>>       END # class
>>>>>END # layer
>>>>>If I look at the MySQL table using OGRinfo I see the following:
>>>>>Layer name: testLine
>>>>>Feature Count: 0
>>>>>Layer SRS WKT:
>>>>>(unknown)
>>>>>FID Coumn = id
>>>>>The issue seems to be that OGRInfo and therefore MapServer does
>>>>> not
>>>>>recognise any features in the table, but QGIS using access to the
>>>>> same
>>>>> table
>>>>>finds and displays the features.
>>>>>Anyone have any ideas what I am doing wrong?
>>>>>Chris
>>> Message: 3
>>> Date: Wed, 27 Jul 2011 15:03:32 +0100
>>> From: "Saber Razmjooei" <razmjooeis at faunalia.co.uk>
>>> To: "Chris Green" <chris.green at ibstv.co.uk>
>>> Message-ID:
>>>  <8f1479b5016f16ec694cce8d304c9e5e.squirrel at www.webmail.lutraconsulting.co.uk>
>>> Content-Type: text/plain;charset=iso-8859-1
>>> Chris
>>> Have you checked this:
>>> 18.4.2.1. Creating Geometry Values Using WKT Functions
>>> http://www.qijoo.com/FAPM/mysql/5.1/MySQL_51_en/ch18s04.html
>>> You can optionally use SRID in your query.
>>> I am a bit out of my depth now as I have never used mysql spatial.
>>> Hope that helps
>>> Saber
>>>> Saber
>>>> Feature Count: 0
>>>> Layer SRS WKT:
>>>> (unknown)
>>>> FID Column = id
>>>> says:
>>>> Feature Count: 34
>>>> Layer SRS WKT:
>>>> (unknown)
>>>> FID Column = id
>>>> is
>>>> lat/lon
>>>> overall.
>>>> I'm not
>>>> saved
>>>> as
>>>> Chris
>>>> To: Chris Green
>>>> located
>>>> properly.
>>>>> Hi Saber
>>>>> shapefile
>>>>> For
>>>>> example
>>>>> if I try
>>>>> could be
>>>>> Then
>>>>> when
>>>>> I try:
>>>>> recognised
>>>>> by
>>>>> MapServer.
>>>>> MySQL
>>>>> Chris
>>>>> To: Chris Green
>>>>> if the
>>>>> MySQL
>>>>> vector might help.
>>>>>>Hi Saber
>>>>>> MySQL
>>>>>> is
>>>>>> the
>>>>>> line
>>>>>> this
>>>>>> then both
>>>>>> OGR
>>>>>> a
>>>>>> format
>>>>>> recognised
>>>>>>by OGR / MapServer.
>>>>>> effort
>>>>>>Chris
>>>>>>To: Chris Green
>>>>>>Chris
>>>>>> But to
>>>>>>ogrinfo --formats
>>>>>>Cheers
>>>>>>Saber
>>>>>>Hi QGIS users
>>>>>> features which
>>>>>> I
>>>>>> for
>>>>>> some
>>>>>> responses,
>>>>>> QGIS,
>>>>>> save
>>>>>> without any
>>>>>> OGRInfo
>>>>>> or
>>>>>> MyISAM
>>>>>> create
>>>>>> a
>>>>>> Vector
>>>>>> Layer'
>>>>>> with this
>>>>>>Chris
>>>>>> database. The
>>>>>> data
>>>>>> saved in
>>>>>> a
>>>>>> properly
>>>>>> nothing
>>>>>> is
>>>>>> example
>>>>>> in
>>>>>>LAYER
>>>>>>       NAME "testLine"
>>>>>>       TYPE   LINE
>>>>>>       STATUS  DEFAULT
>>>>>>       CONNECTIONTYPE  OGR
>>>>>>       CONNECTION
>>>>>>       CLASS
>>>>>>              STYLE
>>>>>>                     COLOR  0 0 0
>>>>>>                     WIDTH  2
>>>>>>              END # style
>>>>>>       END # class
>>>>>>END # layer
>>>>>>Feature Count: 0
>>>>>>Layer SRS WKT:
>>>>>>(unknown)
>>>>>>FID Coumn = id
>>>>>> not
>>>>>> same
>>>>>> table
>>>>>>Chris
>>> Message: 4
>>> Date: Wed, 27 Jul 2011 08:19:23 -0700 (PDT)
>>> From: adamu eloji <aeloji60 at yahoo.com>
>>> Subject: [Qgis-user] Deleting a column from attribute table
>>> To: qgis-user at lists.osgeo.org
>>> Message-ID:
>>>  <1311779963.99219.YahooMailClassic at web114719.mail.gq1.yahoo.com>
>>> Dear All,
>>>             As a novice in QGIS, i created a column on an attribute
>>> which i dont want any more, pls can any experience person tell me how
>>> to delete the column.
>>> Thanks
>>> El-Oji
>>> --- On Wed, 7/27/11, qgis-user-request at lists.osgeo.org
>>> From: qgis-user-request at lists.osgeo.org
>>> Subject: Qgis-user Digest, Vol 65, Issue 61
>>> Date: Wednesday, July 27, 2011, 11:14 AM
>>> Today's Topics:
>>>    1. Re: object labels (Andreas Neumann)
>>>    3. RE: QGIS -> MySQL -> Mapserver ?? (Saber)
>>>    4. DTclassifier is released (Maxim Dubinin)
>>> Message: 1
>>> Date: Wed, 27 Jul 2011 11:00:01 +0200
>>> From: Andreas Neumann <a.neumann at carto.net>
>>> Subject: Re: [Qgis-user] object labels
>>> To: <qgis-user at lists.osgeo.org>
>>> Message-ID: <2634cc5e1e8f0d3a1c3ecba07210ba79 at carto.net>
>>> Content-Type: text/plain; charset=UTF-8; format=flowed
>>> Hi,
>>> Currently, you have to create a new column. I usually create a view
>>> in
>>> Postgis for this purpose.
>>> It is in on the wishlist that one can create a "virtual" column -
>>> not
>>> only for labeling, but also for map tips and perhaps symbolization.
>>> Until then you have to do it yourself.
>>> Andreas
>>> On Tue, 26 Jul 2011 22:51:34 +0200, Torsten Lange wrote:
>>>> Hi,
>>>> Is there a way just to print - lets say - the first four letters
>>>> of a
>>>> objects
>>>> name? Or must I create a new row for that?
>>>> Thank you, Torsten
>>> Andreas Neumann
>>> Böschacherstrasse 10A
>>> 8624 Grüt (Gossau ZH)
>>> Switzerland
>>> Message: 2
>>> Date: Wed, 27 Jul 2011 10:00:27 +0100
>>> Message-ID: <02a401cc4c3b$a25fa3a0$e71eeae0$@green at ibstv.co.uk>
>>> Hi Saber
>>> MySQL is
>>> the line
>>> this
>>> problem - I can create, save, and display points with QGIS and then
>>> both OGR
>>> format
>>> recognised
>>> by OGR / MapServer.
>>> effort
>>> Chris
>>> To: Chris Green
>>> Chris
>>> I presume your ogr can handle mysql if you can open it in QGIS. But
>>> to
>>> ogrinfo --formats
>>> Cheers
>>> Saber
>>> Hi QGIS users
>>> which I
>>> for some
>>> responses,
>>> QGIS, save
>>> without any
>>> OGRInfo or
>>> MyISAM
>>> create a
>>> Vector Layer'
>>> this
>>> Chris
>>> I'm having some trouble with an OGR connection to a MySQL database.
>>> The data
>>> saved in a
>>> properly
>>> nothing is
>>> example in
>>> LAYER
>>>        NAME "testLine"
>>>        TYPE   LINE
>>>        STATUS  DEFAULT
>>>        CONNECTIONTYPE  OGR
>>>        CONNECTION
>>>        CLASS
>>>               STYLE
>>>                      COLOR  0 0 0
>>>                      WIDTH  2
>>>               END # style
>>>        END # class
>>> END # layer
>>> Feature Count: 0
>>> Layer SRS WKT:
>>> (unknown)
>>> FID Coumn = id
>>> The issue seems to be that OGRInfo and therefore MapServer does not
>>> same table
>>> Chris
>>> URL:
>>> http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/414a5aee/attachment-0001.html
>>> Message: 3
>>> Date: Wed, 27 Jul 2011 10:55:20 +0100
>>> From: Saber <razmjooeis at faunalia.co.uk>
>>> To: Chris Green <chris.green at ibstv.co.uk>
>>> Message-ID:
>>> <05cdp715sy1xrat8ywciguee.1311760349356 at email.android.com>
>>> Content-Type: text/plain; charset=utf-8
>>> As a test, worth converting the mysql vector to shapefile to see if
>>> the vector is shown properly.
>>> MySQL vector might help.
>>>>Hi Saber
>>>> MySQL is
>>>> the line
>>>> this
>>>> both OGR
>>>> format
>>>> recognised
>>>>by OGR / MapServer.
>>>> effort
>>>>Chris
>>>>To: Chris Green
>>>>Chris
>>>> to
>>>>ogrinfo --formats
>>>>Cheers
>>>>Saber
>>>>Hi QGIS users
>>>> which I
>>>> for some
>>>> responses,
>>>> QGIS, save
>>>> without any
>>>> OGRInfo or
>>>> MyISAM
>>>> create a
>>>> Vector Layer'
>>>> this
>>>>Chris
>>>> The data
>>>> saved in a
>>>> properly
>>>> nothing is
>>>> example in
>>>>LAYER
>>>>       NAME "testLine"
>>>>       TYPE   LINE
>>>>       STATUS  DEFAULT
>>>>       CONNECTIONTYPE  OGR
>>>>       CONNECTION
>>>>       CLASS
>>>>              STYLE
>>>>                     COLOR  0 0 0
>>>>                     WIDTH  2
>>>>              END # style
>>>>       END # class
>>>>END # layer
>>>>Feature Count: 0
>>>>Layer SRS WKT:
>>>>(unknown)
>>>>FID Coumn = id
>>>> same table
>>>>Chris
>>> Message: 4
>>> Date: Wed, 27 Jul 2011 14:09:39 +0400
>>> From: Maxim Dubinin <sim at gis-lab.info>
>>> Subject: [Qgis-user] DTclassifier is released
>>> To: qgis-developer at lists.osgeo.org
>>> Message-ID: <77239752.20110727140939 at gis-lab.info>
>>> Content-Type: text/plain; charset=us-ascii
>>> Hi all,
>>> To follow up on our demonstration in Lisbon.
>>> We  are happy to release our new plugin for streamlined remote
>>> sensing
>>> data    classification    in    QGIS    [0].  Initially the plugin
>>> was
>>> developed   to   provide   easy  to  use  tool to monitor forest
>>> cover
>>> change, but it can be used to classify any type of targets.
>>> Main features:
>>> -  all-in-one, with this plugin only QGIS is needed for all steps
>>> of
>>> classification;
>>> -  decision trees,  the  plugin  is  using  computer  vision
>>> library OpenCV to
>>> implement  modern  classification algorithm typically not available
>>> in
>>> other software packages (both OS and proprietory);
>>> -   performance,   another   nice  feature  of  OpenCV  is  that it
>>> is
>>> very fast;
>>> - multiple input rasters and multiple training layers;
>>> Description, examples and sample data:
>>> EN: http://gis-lab.info/qa/dtclassifier-eng.html
>>> RU: http://gis-lab.info/qa/dtclassifier.html
>>> Right now the windows binaries and source code are available.
>>> Maxim
>>> [0] http://www.nextgis.ru/projects/dtclassifier
>>> End of Qgis-user Digest, Vol 65, Issue 61
>>> URL:
>>> http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/2d5a5976/attachment.html
>>> End of Qgis-user Digest, Vol 65, Issue 64
 Andreas Neumann
 Switzerland
