[Qgis-user] PgVersion Revision 0.9.2
maning sambale
emmanuel.sambale at gmail.com
Wed Jul 27 23:50:58 PDT 2011
Dear Horst,
On my test, the rollback option is working. Process:
1. Load the versioned layer
2. Edit
3. Commit changes
4. Vie changelog and tried rollback one version lower.
5. Commit changes.
In trying the Checkout Revision to memory layer, I get this error:
An error has occured while executing Python code:
File "/home/maning/.qgis/python/plugins/pgversion/pgVersion.py",
line 310, in doCheckout
mLogProvider.addAttributes( myFieldDefList)
AttributeError: 'NoneType' object has no attribute 'addAttributes'
Python version:
2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
[GCC 4.5.2]
QGIS version:
1.7.0-Wroclaw Wroclaw, exported
Python path: ['/usr/share/qgis/python', '/home/maning/.qgis/python',
'/home/maning/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
'/usr/local/lib/python2.7/dist-packages/Sphinx-1.0.7-py2.7.egg',
'/usr/local/lib/python2.7/dist-packages/docutils-0.7-py2.7.egg',
'/usr/local/lib/python2.7/dist-packages/Jinja2-2.5.5-py2.7.egg',
'/usr/local/lib/python2.7/dist-packages/Pygments-1.4-py2.7.egg',
'/usr/local/lib/python2.7/dist-packages/mbutil-0.0.1-py2.7.egg',
'/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/Numeric',
'/usr/lib/python2.7/dist-packages/PIL',
'/usr/lib/pymodules/python2.7/gtk-2.0',
'/usr/lib/python2.7/dist-packages/gst-0.10',
'/usr/lib/python2.7/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.7',
'/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
'/usr/lib/pymodules/python2.7/libubuntuone',
'/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
'/usr/lib/pymodules/python2.7/ubuntuone-client',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
'/usr/share/qgis/python/plugins/fTools/tools']
On Tue, Jul 26, 2011 at 8:05 PM, Horst Düster <horst.duester at kappasys.ch> wrote:
> Hi
> I just published the new release 0.9.1 of pgversion. Inside of the new
> LogView you now have two new options:
> 1. Rollback to revision. That means that you lift up a specific revision
> into the HEAD revision.
> 2. Checkout Revision to memory layer: with this option a specific revision
> will be checked out to a memory layer for further work with this layer.
> Please note, that memory layer are not persistant. You have to save the
> layer to a file format of your choice.
> I hope that pgversion and pgvs are helpful for you. I'll appreciate any
> comments, hints or bug reports.
> Regards
> Horst
> Dr. Horst Düster
> Burchacker 6
> CH-4556 Aeschi
> Tel.: +41(0)62 961 03 74
> Mobil: +41(0)76 408 51 06
> E-Mail: horst.duester at kappasys.ch
> Skype: horstduester
> Web: http://www.kappasys.ch
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
