[Qgis-user] PgVersion Revision 0.9.2
Horst Düster horst.duester at kappasys.ch
Thu Jul 28 02:04:18 PDT 2011
Hi Maning
Please upgrade to revision 0.9.3. The checkout error is a bug which
should be solved in 0.9.3. Please give it a try and let me know if it works.
Regards
Horst
Am 28.07.2011 08:50, schrieb maning sambale:
> Dear Horst,
> On my test, the rollback option is working.  Process:
> 1. Load the versioned layer
> 2. Edit
> 3. Commit changes
> 4. Vie changelog and tried rollback one version lower.
> 5. Commit changes.
> In trying the Checkout Revision to memory layer, I get this error:
> An error has occured while executing Python code:
> Traceback (most recent call last):
>    File "/home/maning/.qgis/python/plugins/pgversion/pgVersion.py",
> line 310, in doCheckout
>      mLogProvider.addAttributes( myFieldDefList)
> AttributeError: 'NoneType' object has no attribute 'addAttributes'
> Python version:
> 2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
> [GCC 4.5.2]
> QGIS version:
> 1.7.0-Wroclaw Wroclaw, exported
> Python path: ['/usr/share/qgis/python', '/home/maning/.qgis/python',
> '/home/maning/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/local/lib/python2.7/dist-packages/Sphinx-1.0.7-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/docutils-0.7-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/Jinja2-2.5.5-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/Pygments-1.4-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/mbutil-0.0.1-py2.7.egg',
> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/Numeric',
> '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/pymodules/python2.7/gtk-2.0',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.7',
> '/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
> '/usr/lib/pymodules/python2.7/libubuntuone',
> '/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
> '/usr/lib/pymodules/python2.7/ubuntuone-client',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> '/usr/share/qgis/python/plugins/fTools/tools']
> On Tue, Jul 26, 2011 at 8:05 PM, Horst Düster<horst.duester at kappasys.ch>  wrote:
>> Hi
>> I just published the new release 0.9.1 of pgversion. Inside of the new
>> LogView you now have two new options:
>> 1. Rollback to revision. That means that you lift up a specific revision
>> into the HEAD revision.
>> 2. Checkout Revision to memory layer: with this option a specific revision
>> will be checked out to a memory layer for further work with this layer.
>> Please note, that memory layer are not persistant. You have to save the
>> layer to a file format of your choice.
>> I hope that pgversion and pgvs are helpful for you. I'll appreciate any
>> comments, hints or bug reports.
>> Regards
>> Horst
>> Dr. Horst Düster
>> Burchacker 6
>> CH-4556 Aeschi
>> Tel.: +41(0)62 961 03 74
>> Mobil: +41(0)76 408 51 06
>> E-Mail: horst.duester at kappasys.ch
>> Skype: horstduester
>> Web: http://www.kappasys.ch
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Horst Düster
Burchacker 6
CH-4556 Aeschi
Tel.: +41 (0) 62 961 03 74
Mobil: +41 (0) 76 408 51 06
eMail: horst.duester at kappasys.ch
skype: horstduester
Web: www.kappasys.ch
