[Qgis-user] Resetting toolbar that disappeared
Andreas Neumann
a.neumann at carto.net
Fri Jul 29 07:03:15 PDT 2011
Thanks Jürgen - it worked fine with the code I got from Robin.
I don't know how it disappeared. I moved it to another place with the
mouse and it suddenly disappeared.
When I executed the code it looked like it moved in from the top of the
window.
Thanks and have a nice weekend!
Andreas
On Fri, 29 Jul 2011 15:38:14 +0200, Jürgen E. Fischer wrote:
> Hi Robin,
> On Fri, 29. Jul 2011 at 15:04:18 +0200, Robin Cura wrote:
>> Just tried some things, that only change this toolbar and not the
>> whole
>> settings :)
>> It's really ugly though, so, might not work for you ^^
> Ok, I wonder what's wrong with that toolbar. One could check if it's
> just
> offscreen with
> qgis.utils.iface.mapNavToolToolBar().geometry()
> and if it is, move it back with
> qgis.utils.iface.mapNavToolToolBar().move(0,0)
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
