[Qgis-user] Resetting toolbar that disappeared
Andreas Neumann a.neumann at carto.net
Fri Jul 29 07:00:47 PDT 2011
 Hi Robin,
 Thank you for this code. It works. It magically appeared from outside
 (the top of the window).
 Thanks,
 Andreas
 On Fri, 29 Jul 2011 15:12:25 +0200, Robin Cura wrote:
> Hi Andreas,
> I'm not sure (don't know why) that my answer to you through the
> mailing-list will work, so, here is the workaround for your problem I
> found.
> Worked on my computer, hope it will for yours :)
> Just read/run this code on QGIS Python console :
> http://osgeo.codepad.org/Gb8nUknr [1]
> Best regards,
> Robin Cura
> Links:
> [1] http://osgeo.codepad.org/Gb8nUknr
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
