[Qgis-user] Beginner: scanned and georeferenced map looks stretched
Magnus Ekhall
magnus.ekhall at gmail.com
Fri Jul 29 11:22:27 PDT 2011
I'm using 1.7 with the "on the fly" box ticked.
I did not know of the GDALTools plugin.
Did you mean the Warp tool? (I can't find any transformation...)
Regards,
Magnus
On 29 July 2011 19:53, Alex Mandel <tech_dev at wildintellect.com> wrote:
> Oh and you have to check the Project on the Fly box (1.7+) in addition
> to selecting the projection.
> Enjoy,
> Alex
> On 07/29/2011 10:45 AM, Alex Mandel wrote:
>> That depends, if you're using 1.7 that should work anything older and it
>> won't. But I actually meant you should use the GDALTools plugin to
>> reproject the file (Transformation).
>> Enjoy,
>> Alex
>> On 07/29/2011 10:32 AM, Magnus Ekhall wrote:
>>> I've tried that by going to Settings -> Project Settings and switching
>>> to SWEREF99 there (immediate coordinate transformation box is ticked).
>>> But nothing happens at all which is surprising.
>>> When I look at the paper map I can see that indeed the SWEREF99
>>> coordinates are square, but the WGS84 are stretched vertically.
>>> Am I doing something wrong with the reprojection?
>>> Regards,
>>> Magnus
>>> On 29 July 2011 19:27, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>>> On 07/29/2011 09:49 AM, Magnus Ekhall wrote:
>>>>> I'm a beginner with qgis and need some help.
>>>>> I've scanned a map and georeferenced it using the plugin.
>>>>> When it appears in qgis it looks stretched: about double as wide as on paper.
>>>>> However, the coordinates are correct. I can load a gpx-file into a
>>>>> vector layer, and it gets overlaid on the correct parts of the raster
>>>>> map.
>>>>> Is there a way to change horizontal and/or vertical scale on the screen?
>>>>> I think the reason might be (please correct me if I'm wrong) that the
>>>>> paper map is originally in SWEREF99, but I georeferenced in using
>>>>> points of WGS84...
>>>>> I tried to georeference it in SWEREF99 directly, but then the gpx
>>>>> tracks would load to completely different areas.
>>>>> Regards,
>>>>> Magnus
>>>> Try reprojecting it to the SWEREF99 and it will likely look more like
>>>> the paper map.
>>>> Enjoy,
>>>> Alex
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
