[Qgis-user] Beginner: scanned and georeferenced map looks stretched
Alex Mandel tech_dev at wildintellect.com
Fri Jul 29 11:45:52 PDT 2011
Yes I meant Warp.
Enjoy,
Alex
On 07/29/2011 11:22 AM, Magnus Ekhall wrote:
> I'm using 1.7 with the "on the fly" box ticked.
> I did not know of the GDALTools plugin.
> Did you mean the Warp tool? (I can't find any transformation...)
> Regards,
> Magnus
> On 29 July 2011 19:53, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> Oh and you have to check the Project on the Fly box (1.7+) in addition
>> to selecting the projection.
>> Enjoy,
>> Alex
>> On 07/29/2011 10:45 AM, Alex Mandel wrote:
>>> That depends, if you're using 1.7 that should work anything older and it
>>> won't. But I actually meant you should use the GDALTools plugin to
>>> reproject the file (Transformation).
>>> Enjoy,
>>> Alex
>>> On 07/29/2011 10:32 AM, Magnus Ekhall wrote:
>>>> I've tried that by going to Settings -> Project Settings and switching
>>>> to SWEREF99 there (immediate coordinate transformation box is ticked).
>>>> But nothing happens at all which is surprising.
>>>> When I look at the paper map I can see that indeed the SWEREF99
>>>> coordinates are square, but the WGS84 are stretched vertically.
>>>> Am I doing something wrong with the reprojection?
>>>> Regards,
>>>> Magnus
>>>> On 29 July 2011 19:27, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>>>> On 07/29/2011 09:49 AM, Magnus Ekhall wrote:
>>>>>> I'm a beginner with qgis and need some help.
>>>>>> I've scanned a map and georeferenced it using the plugin.
>>>>>> When it appears in qgis it looks stretched: about double as wide as on paper.
>>>>>> However, the coordinates are correct. I can load a gpx-file into a
>>>>>> vector layer, and it gets overlaid on the correct parts of the raster
>>>>>> map.
>>>>>> Is there a way to change horizontal and/or vertical scale on the screen?
>>>>>> I think the reason might be (please correct me if I'm wrong) that the
>>>>>> paper map is originally in SWEREF99, but I georeferenced in using
>>>>>> points of WGS84...
>>>>>> I tried to georeference it in SWEREF99 directly, but then the gpx
>>>>>> tracks would load to completely different areas.
>>>>>> Regards,
>>>>>> Magnus
>>>>> Try reprojecting it to the SWEREF99 and it will likely look more like
>>>>> the paper map.
>>>>> Enjoy,
>>>>> Alex
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
