Print Composer Re: [Qgis-user] Bugs,	release of 1.7 and release of 1.7 as beta
    Ramon Andinach
    custard at westnet.com.au
    Wed Jun  8 04:23:58 PDT 2011
On 08/06/2011, at 02:47 , Andreas Neumann wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
>> Two for grids:
>> 1. At times I'd like some options other than solid lines or crosses for grid lines. Probably dashed or dotted lines would do.
> this would be probably easy to do.
>> 2. At other times I'd really like an easier way to put up grids in two different projections. I know Micha has some instructions on doing this (http://www.surfaces.co.il/?p=616) but it would be really cool to be able to do it inside the print composer.
> probably more work. If you seriously need this, you can ask Marco for an
> offer/estimate how many hours of work. Other people asked for this
> feature as well. So maybe an opportunity to combine financial resources
> for implementing it?
>> 3. I'm noticing that when I browse to a folder with images, the path is reported with \ in the opposite direction to the default set, causing QGIS to loose my added directory. Can anyone else using Windows osgeo install confirm this?
> don't have the Windows version at hand currently.
Ok, scrap this one. It's something like this, but isn't quite that simple. It might have something to do with bringing in templates with local images on - but I'll need to play with it a bit more to see if I can refine it better.
-ramon.
