Print Composer Re: [Qgis-user] Bugs, release of 1.7 and release of 1.7 as beta
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Wed Jun 8 05:27:47 PDT 2011
Hi all
Thank you for the feedback. To collect the ideas, please add them to the wiki
(http://www.qgis.org/wiki/Ideas_for_enhancement_print_composer)
Regards,
Marco
Am Dienstag, 7. Juni 2011, 20.47:04 schrieb Andreas Neumann:
> > Two for grids:
> > 1. At times I'd like some options other than solid lines or crosses for
> > grid lines. Probably dashed or dotted lines would do.
> this would be probably easy to do.
> > 2. At other times I'd really like an easier way to put up grids in two
> > different projections. I know Micha has some instructions on doing this
> > (http://www.surfaces.co.il/?p=616) but it would be really cool to be
> > able to do it inside the print composer.
> probably more work. If you seriously need this, you can ask Marco for an
> offer/estimate how many hours of work. Other people asked for this
> feature as well. So maybe an opportunity to combine financial resources
> for implementing it?
> > 3. I'm noticing that when I browse to a folder with images, the path is
> > reported with \ in the opposite direction to the default set, causing
> > QGIS to loose my added directory. Can anyone else using Windows osgeo
> > install confirm this?
> don't have the Windows version at hand currently.
> > 4. I'm also interested in the multicolumn feature.
> the Swiss QGIS users discussed this already. I have to check tomorrow if
> this is already in the pipeline (if we already have a sponsor). Will let
> you know tomorrow.
> Andreas
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
