[Qgis-user] gdal tools
Giovanni Manghi
giovanni.manghi at gmail.com
Sat Jun 11 08:27:09 PDT 2011
> "python" no se reconoce como un comando interno o externo, programa o
> archivo por lotes ejecutable (that is: phyton is not recognized as
> internal or external command, programm or batch file).
check if the "path to the gdal binaries" is properly set in the gdal
tools settings
> Also, if I try to
> do some other operation, like rasterize vectors I get this:
> ERROR 1: Can't load requested DLL:
> C:\Downloads\bin\gdalplugins\1.8\gdal_ECW_JP2ECW.dll
> 126: No se puede encontrar el módulo especificado.
> C:\Downloads\bin\gdalplugins\1.8\gdal_MG4Lidar.dll
> C:\Downloads\bin\gdalplugins\1.8\gdal_MrSID.dll
your is install folder is a bit strange... in any case this messages
usually do show when you install a library like gdal-ecw and then you
actually don't copy the necessary .dll from ERDAS in the osgeo4w "bin"
folder (or worst in the "system32" folder).
cheers
-- Giovanni --
