[Qgis-user] Interpolation of contour lines
Saber Razmjooei
razmjooeis at faunalia.co.uk
Mon Jun 13 13:18:10 PDT 2011
> Actually not so much "converting" as it would be "adding" based on
> existing 10m.
By "converting" I meant "interpolate"...(OP:and I would like to
interpolate each 5 meters)
> Could choose to merge the '5m buffered lines' afterwards, or not.
> Of course if there is a DEM with 5m resolution or better,
You can create contours with 5 m intervals from a 50 m resolution DEM.
> it would be
> more accurate to use the Contour.plugin (need matplotlib installed) or
> GRASS.
> Just depends on what data is available and use case.
Cheers
Saber
> On Mon, Jun 13, 2011 at 11:50 AM, Saber Razmjooei
> <razmjooeis at faunalia.co.uk> wrote:
> I guess Mars meant converting a contour lines of 10 metre
> intervals to 5
> metre.
> Best to do it using GRASS (plugin). Here is a nice Wiki page:
> http://grass.osgeo.org/wiki/Contour_lines_to_DEM
> Once you have it as DEM (i.e. raster) you can use r.contour in
> GRASS or
> Contour tool under GDAL in QGIS (Raster > Contour) to convert
> it to 5
> metre contour vector.
> Saber
> On Mon, 2011-06-13 at 11:31 -0700, Mars Sjoden wrote:
> > Why not buffer a left or right side of your contour line @
> 5m?
> > I presume your contour lines are vector polylines.
> > Unless you mean to interpolate from an existing DEM?
> > mars
> > 2011/6/13 Vincent Blanqué <vblanque at oriondata.cl>
> > Hi,
> > I have contour lines each 10 meters and I would like
> to
> > interpolate each 5 meters. Is there any Qgis
> functionality to
> > generate these? Any plugin? Or is it possible with
> ogr2ogr?
> > thx,
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
