[Qgis-user] Interpolation of contour lines
Vincent Blanqué
vblanque at oriondata.cl
Mon Jun 13 13:55:24 PDT 2011
Hi, thanks for your solutions in fact. I have edited the 10m contour
lines and I just want to make contour isolines to 5m from the 10m
shapefile (vectors) without using any intermediar DEM or TIN. Maybe
Grass has a such function to interpolate vectors not only rasters?
For now, we take the decision to to calculate 5 meter contour lines and
to merge only the new curves and editing the bad ones in the flat zone.
thx for trying to help me,
Enzopolo
On 13/06/2011 16:18, Saber Razmjooei wrote:
>> Actually not so much "converting" as it would be "adding" based on
>> existing 10m.
> By "converting" I meant "interpolate"...(OP:and I would like to
> interpolate each 5 meters)
>> Could choose to merge the '5m buffered lines' afterwards, or not.
>> Of course if there is a DEM with 5m resolution or better,
> You can create contours with 5 m intervals from a 50 m resolution DEM.
>> it would be
>> more accurate to use the Contour.plugin (need matplotlib installed) or
>> GRASS.
>> Just depends on what data is available and use case.
> Cheers
> Saber
>> On Mon, Jun 13, 2011 at 11:50 AM, Saber Razmjooei
>> <razmjooeis at faunalia.co.uk> wrote:
>> I guess Mars meant converting a contour lines of 10 metre
>> intervals to 5
>> metre.
>> Best to do it using GRASS (plugin). Here is a nice Wiki page:
>> http://grass.osgeo.org/wiki/Contour_lines_to_DEM
>> Once you have it as DEM (i.e. raster) you can use r.contour in
>> GRASS or
>> Contour tool under GDAL in QGIS (Raster> Contour) to convert
>> it to 5
>> metre contour vector.
>> Saber
>> On Mon, 2011-06-13 at 11:31 -0700, Mars Sjoden wrote:
>> > Why not buffer a left or right side of your contour line @
>> 5m?
>> > I presume your contour lines are vector polylines.
>> > Unless you mean to interpolate from an existing DEM?
>> > mars
>> > 2011/6/13 Vincent Blanqué<vblanque at oriondata.cl>
>> > Hi,
>> > I have contour lines each 10 meters and I would like
>> to
>> > interpolate each 5 meters. Is there any Qgis
>> functionality to
>> > generate these? Any plugin? Or is it possible with
>> ogr2ogr?
>> > thx,
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Vincent Blanqué
Oriondata Ltda.
http://www.oriondata.cl
Fono: +56 (2) 235 64 44 / Fax: +56 (2) 264 18 24
Cel: +56 (9) 872 34 625
Antonio Bellet 77, Of. 1002, Providencia, Chile
