[Qgis-user] raster error ubuntu qgis 1.7
Pedro Tarroso ptarroso at mail.icav.up.pt
Tue Jun 14 03:59:14 PDT 2011
I just found the origin of the segmentation fault problem in my case. It was the SDA4PP plugin causing the SegFault whenever I opened a raster. I don't know if the problem is related to yours because I couldn't open at all any kind of raster (vector data was ok).
However, the second strange behaviour I described still happens.. Even if I delete the ~/.qgis it opens in the next workspace to the current...
-----Original Message-----
From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
Sent: Tue 6/14/2011 11:47 AM
To: Pedro Tarroso
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] raster error ubuntu qgis 1.7
I'm seeing the same problem (also in trunk), and it seems to be the
cause of the slowness  when opening rasters (that can lead in crashes as
reported here)
see also
http://hub.qgis.org/issues/3867
cheers
-- Giovanni --
error message
Warning: Object::connect: No such signal
QgsGdalProvider::statusChanged( QString ) in /tmp/buildd/qgis-1.8.0
+git20110613+a954488~lucid1/src/core/raster/qgsrasterlayer.cpp:2506
ERROR 5: Access window out of range in RasterIO().  Requested
(40448,0) of size 256x256 on raster of 40515x53718.
(40448,256) of size 256x256 on raster of 40515x53718.
(40448,512) of size 256x256 on raster of 40515x53718.
(40448,768) of size 256x256 on raster of 40515x53718.
(40448,1024) of size 256x256 on raster of 40515x53718.
(40448,1280) of size 256x256 on raster of 40515x53718.
(40448,1536) of size 256x256 on raster of 40515x53718.
(40448,1792) of size 256x256 on raster of 40515x53718.
(40448,2048) of size 256x256 on raster of 40515x53718.
(40448,2304) of size 256x256 on raster of 40515x53718.
(40448,2560) of size 256x256 on raster of 40515x53718.
(40448,2816) of size 256x256 on raster of 40515x53718.
(40448,3072) of size 256x256 on raster of 40515x53718.
(40448,3328) of size 256x256 on raster of 40515x53718.
(40448,3584) of size 256x256 on raster of 40515x53718.
(40448,3840) of size 256x256 on raster of 40515x53718.
On Tue, 2011-06-14 at 11:30 +0100, Pedro Tarroso wrote:
> Hi
> My ubuntu just updated qgis to the version 1.7 but qgis is almost
> useless now... I can't open any raster. I get this error:
> in /build/buildd/qgis-1.7.0~lucid1/src/core/raster/qgsrasterlayer.cpp:2504
> Error:
>         GDAL Error 5: Access window out of range in RasterIO().
> Requested
> (0,84) of size 165x12 on raster of 165x92.
> Segmentation fault
> Another strange behaviour that didn't happen before: qgis now opens
> the gui in the workspace next to the one I'm using...
> Any solutions?
> Cheers,
> Pedro
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110614/338610a2/attachment.html>
