[Qgis-user] raster error ubuntu qgis 1.7
Giovanni Manghi
giovanni.manghi at gmail.com
Tue Jun 14 04:03:56 PDT 2011
> I just found the origin of the segmentation fault problem in my case.
> It was the SDA4PP plugin causing the SegFault whenever I opened a raster.
> I don't know if the problem is related to yours because I couldn't open at all any kind of raster (vector data was ok).
I don't have the SDA4PP plugin installed and I still see the error
messages below and have many problems to open rasters (it takes a lot of
time, the more the raster is big the more it takes, even big rasters
with overviews that under 1.6 where opened in a eye blink)
> error message
> Warning: Object::connect: No such signal
> QgsGdalProvider::statusChanged( QString ) in /tmp/buildd/qgis-1.8.0
> +git20110613+a954488~lucid1/src/core/raster/qgsrasterlayer.cpp:2506
> ERROR 5: Access window out of range in RasterIO(). Requested
> (40448,0) of size 256x256 on raster of 40515x53718.
> (40448,256) of size 256x256 on raster of 40515x53718.
> (40448,512) of size 256x256 on raster of 40515x53718.
> (40448,768) of size 256x256 on raster of 40515x53718.
> (40448,1024) of size 256x256 on raster of 40515x53718.
> (40448,1280) of size 256x256 on raster of 40515x53718.
> (40448,1536) of size 256x256 on raster of 40515x53718.
> (40448,1792) of size 256x256 on raster of 40515x53718.
> (40448,2048) of size 256x256 on raster of 40515x53718.
> (40448,2304) of size 256x256 on raster of 40515x53718.
> (40448,2560) of size 256x256 on raster of 40515x53718.
> (40448,2816) of size 256x256 on raster of 40515x53718.
> (40448,3072) of size 256x256 on raster of 40515x53718.
> (40448,3328) of size 256x256 on raster of 40515x53718.
> (40448,3584) of size 256x256 on raster of 40515x53718.
> (40448,3840) of size 256x256 on raster of 40515x53718.
