[Qgis-user] QGIS slow on PostGIS
pcreso at pcreso.com
Fri Jun 17 17:15:57 PDT 2011
Try connecting to public schema & geometry columns only (setup in the db connection dialogue)
If you have views with geometries, QGIS will otherwise try to ascertain their geometry contents, which can take some time depending on the view.
HTH,
Brent Wood
--- On Sat, 6/18/11, Frank Aragona <frank at agroinnovations.com> wrote:
Subject: [Qgis-user] QGIS slow on PostGIS
To: qgis-user at lists.osgeo.org
Date: Saturday, June 18, 2011, 10:38 AM
I am running QGIS 1.6. When I add a PostGIS database layer, everything
loads up ok, but when I go to open or query the attribute table, QGIS
hangs. Eventually, the attribute table opens, but the hanging continues,
and generally results in QGIS crashing.
I don't think this is my PostGIS configuration, because I've opened the
same PostGIS layers and attribute tables in both Open Jump and uDig
without any slow down, hanging, or crashing.
Is this a bug? A configuration error? Any advice?
Frank
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110617/8e2bb98e/attachment.html>
