[Qgis-user] Raster -> Merge (gdal_merge) failure
    Giovanni Manghi
    giovanni.manghi at gmail.com
    Sat Jun 18 03:20:27 PDT 2011
> I had the same problem with Qgis 1.6, some gdaltools work very well but
> by using others (like merge) I get an error message saying that qgis
> can't find some modules, they are there (but I don't know if they are on
> the wrong place). Anyway, I solved the problem by constructing a vtr of
> the rasters I want (this tool works fine) and then I transformed the vtr
> to another format I needed (this one also works very well). I know that
> this is not very elegant solution but it could be useful if you can't
> wait for long.
if you are using windows/standalone you have to set the "path to the
GDAL binaries" in the gdal tools settings.
> > I am running QGIS 1.7 under Ubuntu 11.04 and I can no longer merge
> > rasters by going 'Raster ->  Merge'. This was possible in QGIS 1.6, but
> > not in QGIS 1.8 or now, after I have dropped back to Version 1.7. The
> > process fails with the error message 'The process crashed some time
> > after starting successfully.' However, other Gdal tools, for example,
> > 'Raster ->  Warp' and 'Raster ->  Transform' do work. gdal_merge.py will
> > not run from a terminal either.
if the tool do not works from the command line then it should be a gdal
problem. How do you install gdal/qgis? using the ubuntugis/nightly build
repositories? both?
> > I have tried completely removing QGIS and reinstalling, but to no
> > effect. One odd thing though, after 'completely removing' QGIS and
> > reinstalling it I was surprised to find that my old settings were
> > still in place.
configurations (not plugins) are in ~/.config/QuantumGIS
cheers
-- Giovanni --
