[Qgis-user] Rubberband class in QGIS 1.7
ASAHI Kosuke
asahi at hcc.co.jp
Mon Jun 20 16:12:21 PDT 2011
Hi giovanni.
Thank you for your reply.
After I adjust it to QGIS 1.7, I will consider.
But still not work....
(2011/06/20 18:21), Giovanni Manghi wrote:
> Hi,
> if the plugin can be useful for the qgis users please consider
> contributing it.
> cheers
> -- Giovanni --
> On Mon, 2011-06-20 at 16:40 +0900, ASAHI Kosuke wrote:
>> Dear All,
>> I made features select plugin used rubberband class and extended
>> QgsMapTool class.
>> It work fine in QGIS 1.6, But not work in QGIS 1.7.
>> After rubberBand.movePoint() in canvasMoveEvent(), it was crashed.
>> Please give me any advice. Is this a bug in QGIS 1.7?
>> All sources are here.
>> http://d.hatena.ne.jp/waigani/files/sweepselect_test2.zip
>> I use rubberband class like this.
>> class QgsMapToolSweepSelect(QgsMapTool):
>> def __init__(self, canvas):
>> QgsMapTool.__init__(self, canvas)
>> self.canvas = canvas
>> self.rubberBand = QgsRubberBand(canvas, True)
>> self.pressed = False
>> def canvasPressEvent(self, event):
>> self.center = self.toMapCoordinates(QPoint(event.pos().x(),
>> event.pos().y()))
>> for cnt in range(0,359):
>> self.rubberBand.addPoint(self.center, False)
>> self.rubberBand.addPoint(self.center, True)
>> self.pressed = True
>> def canvasMoveEvent(self, event):
>> if self.pressed == True:
>> cpos = self.toMapCoordinates(QPoint(event.pos().x(),
>> event.pos().y()))
>> len = math.sqrt((self.center.x()-cpos.x())**2 +
>> (self.center.y()-cpos.y())**2)
>> for cnt in range(0,361):
>> x = math.cos(math.radians(cnt)) * len + self.center.x()
>> y = math.sin(math.radians(cnt)) * len + self.center.y()
>> self.rubberBand.movePoint(cnt, QgsPoint(x,y))
>> def canvasReleaseEvent(self, event):
>> layer = self.canvas.currentLayer()
>> if layer == None or layer.type() != QgsMapLayer.VectorLayer:
>> self.rubberBand.reset()
>> return
>> layer.removeSelection()
>> circle = self.rubberBand.asGeometry()
>> fid = []
>> provider = layer.dataProvider()
>> provider.select([], circle.boundingBox(), True, True)
>> feat = QgsFeature()
>> while provider.nextFeature(feat):
>> if circle.intersects(feat.geometry()):
>> fid.append(feat.id())
>> for id in fid:
>> layer.select(id)
>> self.rubberBand.reset(True)
ASAHI Kosuke
