RES: [Qgis-user] "join attributes by location" and "join attrtibutes" - ftools
Frederico Mestre
mestre.frederico at gmail.com
Sun Jun 26 11:52:43 PDT 2011
Hi Giovanni,
I just did this... Solved my problem.
Thanks,
Frederico Mestre
-----Mensagem original-----
De: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
Enviada em: domingo, 26 de Junho de 2011 19:25
Para: Frederico Mestre
Cc: qgis-user at lists.osgeo.org
Assunto: Re: [Qgis-user] "join attributes by location" and "join attrtibutes" - ftools
Hi Fred,
to Join attributes use the new Join tool you can find in the vector properties of qgis 1.7. To add geometryless tables (.csv) to the project use the "add vector layer" dialog.
Can you share a sample of your data to try do the "join attributes by location" locally and so try replicate the issue?
cheers
-- Giovanni --
On Sun, 2011-06-26 at 19:15 +0100, Frederico Mestre wrote:
> Hello list,
> I´m having some problems with the function “join attributes by
> location” and “join attrtibutes” of ftools.
> Qgis doesn’t deliver any result and just stops at 13-15% and then just
> doesn’t respond…
> Any help?
> Frederico Mestre
> Qgis-user mailing list
