[Qgis-user] Re: Bookmarks
Alister Hood alister.hood at synergine.com
Mon Jun 27 18:13:47 PDT 2011
Ah.
 -----Original Message-----
> From: Chuck Young [mailto:wylie1066 at gmail.com]
> Sent: Tuesday, 28 June 2011 9:40 a.m.
> To: Alister Hood
> Subject: Re: [Qgis-user] Re: Bookmarks
> What I found is that the Spatialite db file "qgis.db" is located in
the
>  Users/(My User Name)/.qgis folder. (I am using Win 7)
Looks like it is a sqlite file, but not a spatialite file :)
I was wondering what I could open it with... QGIS of course!
> To replicate the bookmarks to another machine just copy that file into
the
> correct position on the new machine. Restart Qgis. That worked fine.
Yes, but this will wipe out some other settings as well, as the file doe
not only include bookmarks.
But what I can do is open the bookmarks table from qgis.db, open the
attribute table, and select and copy all the rows.
Then I can open the bookmarks table from qgis.db on the target computer,
toggle editing and do "Edit-Paste features".
> After I did that I also worked to try to set up a bit different sort.
I
> exported the tbl_bookmarks table to CSV the sort and re-index and
re-import,
> but that added some kind of character in front of the xmin field which
trhew
> all references off. I used MS Excel 2010 to do the csv work so there
is
> probably a glitch in the csv format between Excel and Spatialite that
added the
> extra character.  After the re-import to a new table all one has to do
is use
> the Spatialite sql query builder to rename the tables.  After the
updates are
> finished you must restart Qgis.
> I think that if the extra character were not there it csv export,
update, re-
> import would have worked fine.
> I will try doing it in MS Access to see if I can get a cleaner set of
records.
> So I went to the spatialite gui and set up a set of update queries to
allow me
> to update names and thus to be able to sort on the name field in the
Bookmark
> form in Qgis.
> I hope this helps.
> Chuck
> On Sun, Jun 26, 2011 at 11:46 PM, Alister Hood
<alister.hood at synergine.com>
> wrote:
> 	Hi, what way are you doing it?
> 	I know of two rather laborious ways:
> 	1) go through the bookmarks one at a time, copying and pasting
from the
> 	coordinate and scale displays at the bottom of the main QGIS
window.
> 	2) go through the bookmarks one at a time, using the "P2P QGIS"
plugin
> 	to grab the window extent of each bookmark.  I wonder if it
would take
> 	much to modify the P2P plugin to also share bookmarks...
> 	Alister
> 	> Date: Sun, 26 Jun 2011 23:07:18 -0700
> 	> From: Chuck Young <wylie1066 at gmail.com>
> 	> Subject: [Qgis-user] Re: Bookmarks
> 	> To: Qgis-user at lists.osgeo.org
> 	> Message-ID:
<BANLkTinFHdLSwixaZHKsrUu9QPevS5PUJA at mail.gmail.com>
> 	> Content-Type: text/plain; charset="iso-8859-1"
> 	> Never mind.  I figured it out.  If anyone else has a question
on this
> 	let me
> 	> know.  There may be another way to do it but what I found
works.
> 	> Thanks
> 	> Chuck
> 	> On Sun, Jun 26, 2011 at 3:19 PM, Chuck Young
> 	wrote:
> 	> > I understand that bookmarks are global at present and that
they are
> 	> > available to all projects.  I would like to / need to have
the
> 	ability to
> 	> > copy the bookmarks from one installation to another so all
those on
> 	the
> 	> > project can use the same bookmarks.
> 	> > I saw some discussion on this from several months ago but it
didn't
> 	seem to
> 	> > be resolved at that time.
> 	> > Is that possible?  Is there a way to save them / export /
import
> 	them to
> 	> > get them to the second machine???
> 	> > Thanks
> 	> > Chuck
Alister
