[Qgis-user] Re: Bookmarks
Alister Hood
alister.hood at synergine.com
Mon Jun 27 21:36:52 PDT 2011
Copying back to the list.
> -----Original Message-----
> From: Chuck Young [mailto:wylie1066 at gmail.com]
> Sent: Tuesday, 28 June 2011 4:34 p.m.
> To: Alister Hood
> Subject: Re: [Qgis-user] Re: Bookmarks
> As always there are things to be careful of. In my case this was the
only data
> in the db that I needed to replicate.
> Note on MS Access to work with bookmarks etc in spatialite:
> I just tried manipulating data in the bookmarks table using MS Access
through
> the ODBC driver for spatialite. Found here: http://www.ch-
> werner.de/sqliteodbc/
> The section where the driver package I needed was here.
> For Win32 operating systems a binary package is available as an
NSIS
> <http://nsis.sf.net/> installer in sqliteodbc.exe <http://www.ch-
> werner.de/sqliteodbc/sqliteodbc.exe> . It was made with SQLite
2.8.17/3.7.6.3
> and a MinGW cross compiler, and contains the driver DLLs and programs
for
> installation and uninstallation of the ODBC driver.
> I added one record to a linked table and opened Qgis, went to the
bookmarks
> form and the added record was there and it went to the coordinates
assigned to
> it.
> Hope this helps!
> Chuck
> On Mon, Jun 27, 2011 at 6:13 PM, Alister Hood
<alister.hood at synergine.com>
> wrote:
> Ah.
> > Sent: Tuesday, 28 June 2011 9:40 a.m.
> > To: Alister Hood
> > What I found is that the Spatialite db file "qgis.db" is
located in
> the
> > Users/(My User Name)/.qgis folder. (I am using Win 7)
> Looks like it is a sqlite file, but not a spatialite file :)
> I was wondering what I could open it with... QGIS of course!
> > To replicate the bookmarks to another machine just copy that
file into
> the
> > correct position on the new machine. Restart Qgis. That worked
fine.
> Yes, but this will wipe out some other settings as well, as the
file doe
> not only include bookmarks.
> But what I can do is open the bookmarks table from qgis.db, open
the
> attribute table, and select and copy all the rows.
> Then I can open the bookmarks table from qgis.db on the target
computer,
> toggle editing and do "Edit-Paste features".
> > After I did that I also worked to try to set up a bit
different sort.
> I
> > exported the tbl_bookmarks table to CSV the sort and re-index
and
> re-import,
> > but that added some kind of character in front of the xmin
field which
> trhew
> > all references off. I used MS Excel 2010 to do the csv work so
there
> is
> > probably a glitch in the csv format between Excel and
Spatialite that
> added the
> > extra character. After the re-import to a new table all one
has to do
> is use
> > the Spatialite sql query builder to rename the tables. After
the
> updates are
> > finished you must restart Qgis.
> > I think that if the extra character were not there it csv
export,
> update, re-
> > import would have worked fine.
> > I will try doing it in MS Access to see if I can get a cleaner
set of
> records.
> > So I went to the spatialite gui and set up a set of update
queries to
> allow me
> > to update names and thus to be able to sort on the name field
in the
> Bookmark
> > form in Qgis.
> > I hope this helps.
> > Chuck
> > On Sun, Jun 26, 2011 at 11:46 PM, Alister Hood
> > wrote:
> > Hi, what way are you doing it?
> > I know of two rather laborious ways:
> > 1) go through the bookmarks one at a time, copying and
pasting
> from the
> > coordinate and scale displays at the bottom of the main
QGIS
> window.
> > 2) go through the bookmarks one at a time, using the
"P2P QGIS"
> plugin
> > to grab the window extent of each bookmark. I wonder if
it
> would take
> > much to modify the P2P plugin to also share bookmarks...
> > Alister
> > > Date: Sun, 26 Jun 2011 23:07:18 -0700
> > > From: Chuck Young <wylie1066 at gmail.com>
> > > Subject: [Qgis-user] Re: Bookmarks
> > > To: Qgis-user at lists.osgeo.org
> > > Message-ID:
> <BANLkTinFHdLSwixaZHKsrUu9QPevS5PUJA at mail.gmail.com>
> > > Content-Type: text/plain; charset="iso-8859-1"
> > > Never mind. I figured it out. If anyone else has a
question
> on this
> > let me
> > > know. There may be another way to do it but what I
found
> works.
> > > Thanks
> > > Chuck
> > > On Sun, Jun 26, 2011 at 3:19 PM, Chuck Young
> > wrote:
> > > > I understand that bookmarks are global at present
and that
> they are
> > > > available to all projects. I would like to / need
to have
> the
> > ability to
> > > > copy the bookmarks from one installation to another
so all
> those on
> > the
> > > > project can use the same bookmarks.
> > > > I saw some discussion on this from several months
ago but it
> didn't
> > seem to
> > > > be resolved at that time.
> > > > Is that possible? Is there a way to save them /
export /
> import
> > them to
> > > > get them to the second machine???
> > > > Thanks
> > > > Chuck
> Alister
