[Qgis-user] Mapfile Tools
Pirmin Kalberer
pi_ml at sourcepole.com
Tue Jun 28 00:45:32 PDT 2011
Hi Derrick,
Am Montag, 27. Juni 2011, um 23.55:09 schrieb Derrick Frese:
> Hi Richard,
> I've downloaded the sources and see a bunch of python scripts. I'm running
> QGIS 1.6.0 on Windows XP. Is there a way to point to these files that are
> stored locally to install the Mapfile Tools? Also, is python-mapscript
> something I need to download or a setting to turn on in QGIS? Not familiar
> with it.
> Thank you for your help.
I've opened ticket: http://hub.qgis.org/issues/4028
I try to get access to a Windows machine and will investigate this pyhton-
mapscript installation issue.
Regards
Pirmin
> Derrick
> >>> Richard Duivenvoorde <rdmailings at duif.net> 6/27/2011 2:48 PM >>>
> On 06/27/2011 09:29 PM, Derrick Frese wrote:
> > New to the user list, so don't know if this has been mentioned before....
> > I get an error when trying to install the Mapfile Tools plugin. I
> > would really like to be able to check this out. Any idea of this will
> > be fixed, ways to get around the problem, etc..?
> Hi Derrick,
> you can find sources:
> https://github.com/sourcepole/qgis-mapfile-tools
> One of the authors is Pirmin Kalberer which is seen on this list pretty
> often also...
> One of the things that you really have to have for this plugin to work
> is python-mapscript.
> Depending on your Operating System or installation type this is
> installed in different ways.
> So please be a little more specific:
> - which version/OS
> - what is the problem
> This makes it easier to provide help or suggestions,
> Regards,
> Qgis-user mailing list
Pirmin Kalberer
Sourcepole - Linux & Open Source Solutions
http://www.sourcepole.com
