[Qgis-user] Best way to store temperature info
Andreas Neumann a.neumann at carto.net
Tue Jun 28 08:45:09 PDT 2011
 I think Jorge wants to store data just at a single point (not a full
 raster). Any QGIS datasource would do: sqlite, PostgreSQL, etc.
 sqlite is easier to exchange with other people, Postgis makes more
 sense in a centralized multiuser environment. Both have good performance
 and SQL capabilities, PostgreSQL is of course more powerful.
 Netcdf would definitely be overkill if one stores temperature values
 just at a single point.
 Andreas
 On Tue, 28 Jun 2011 16:28:41 +0100, M.E.Dodd wrote:
> I have tried to work with with this format and find it a nightmare to
> deal with unless you are a experienced programmer and work with this
> kind of information all the time, i.e. you spend ages learning then
> its ok, I did not manage to get there.  Incidentally can qgis deal
> with it, think I asked this question a year or two ago and I suspect
> the answer was no although I may be wrong.
> -----Original Message-----
> From: Noli Sicad [mailto:nsicad at gmail.com]
> Sent: 28 June 2011 01:06
> To: jorge.canelhas at binarium.pt
> Cc: Qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Best way to store temperature info
> I think the best way is NetCDF.
> http://en.wikipedia.org/wiki/NetCDF
> http://www.mail-archive.com/search?q=GDAL+and+.nc+%28netCDF%29+and+qgis&l=qgis-user%40lists.osgeo.org
> Noli
> On 6/28/11, jorge.canelhas at binarium.pt <jorge.canelhas at binarium.pt>
> wrote:
>> Hi all
>> what do you think is the best way to store temerature data in one
>> poin?
>> using attributes ? like Time, Date , Temp in a simgle point and keep
>> repeating that point ? or can I have something like a relational DB
>> on
>> a shapefile ? or should I use postgis to achieve that ?
>> Thanks
>> Jorge
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
