[Qgis-user] Saga plugin:require python module processingpluging exists for windows only
Alex Mandel tech_dev at wildintellect.com
Tue Jun 28 11:42:31 PDT 2011
On 06/28/2011 09:46 AM, Agustin Lobo wrote:
> After having solved the problem with the python bindings of saga
> thanks to Johan
>  the installation of the saga plugin under ubuntu lucid still complains:
> " You need to install the following Python module in order to enable
> it: processingpluging"
> Nevertheless, I cannot find that module for ubuntu (not listed by
> Synaptic), do I have to compile it from source?
> (installers provided for windows only in
> http://pypi.python.org/pypi/processing#downloads)
> Thanks
> Agus
I believe that it's another QGIS plugin as described in Camilo's summer
of code updates. The processing is the framework for various add on's
like SAGA (Potentially Orfeo OTB from what I've read).
Should be in the Faunalia repo from what I can tell (marked as
experimental).
[1] https://github.com/polymeris/qgis/wiki/QGIS-Processing-Framework
[2] https://github.com/polymeris/qgis/wiki/Reports
[3] https://github.com/polymeris/qgis
Thanks,
Alex
