[Qgis-user] Saga plugin:require python module processingpluging exists for windows only
Agustin Lobo
alobolistas at gmail.com
Tue Jun 28 12:02:33 PDT 2011
Yes, thanks! The message is quite confusing.
Agus
2011/6/28 Alex Mandel <tech_dev at wildintellect.com>:
> On 06/28/2011 09:46 AM, Agustin Lobo wrote:
>> After having solved the problem with the python bindings of saga
>> thanks to Johan
>> the installation of the saga plugin under ubuntu lucid still complains:
>> " You need to install the following Python module in order to enable
>> it: processingpluging"
>> Nevertheless, I cannot find that module for ubuntu (not listed by
>> Synaptic), do I have to compile it from source?
>> (installers provided for windows only in
>> http://pypi.python.org/pypi/processing#downloads)
>> Thanks
>> Agus
> I believe that it's another QGIS plugin as described in Camilo's summer
> of code updates. The processing is the framework for various add on's
> like SAGA (Potentially Orfeo OTB from what I've read).
> Should be in the Faunalia repo from what I can tell (marked as
> experimental).
> [1] https://github.com/polymeris/qgis/wiki/QGIS-Processing-Framework
> [2] https://github.com/polymeris/qgis/wiki/Reports
> [3] https://github.com/polymeris/qgis
> Thanks,
> Alex
> Qgis-user mailing list
