[Qgis-user] Re: Editing polygons
Kai-Christian Bruhn
bruhn at fh-mainz.de
Tue Jun 28 13:35:37 PDT 2011
Hi Jorge,
your solution is surely much more appropriate. Thanks for the links to
the vid-tutorials!
Kai
Am 28.06.2011 22:16, schrieb jorgepsantos2002:
> Hi Laura,
> You must use the *Reshape Feature tool* to edit these features under
> topologic rules. Press the right button of mouse to finalize the scretch.
> See the video:
> http://www.youtube.com/watch?v=XgL2OTpBNaY
> Best wishes,
> _________________
> Jorge Santos
> Téc. em Geodésia e Cartografia
> http://processamentodigital.blogspot.com/
> http://twitter.com/jpsantos2002
> Skype: jorgepsantos2002
> Laura Guillot wrote:
>> I'm trying to reshape polygons of a lancover map, in order to make them to
>> be more
>> coincident with an overlaid raster image (orthophoto 1:5M).
>> If I just move the nodes to the correct position, I create a correct line
>> but leave a hole behind: the other
>> polygon keeps its line where it was. See a pict here:
>> http://osgeo-org.1803224.n2.nabble.com/file/n6526418/boundaryproblem.jpeg
>> Is there any way I could just move the lines as boundaries?
>> I've tried by converting poygons to lines first, but the problem is very
>> much the same: it seems like
>> there is always a double line, one for each adjacent polygon.
>> A possible solution would be having the lines automatically cut into
>> segments, each going from one vertex to another.
>> And having just one segment for each boundary. Is that possible? Is there
>> a
>> process to cut into segments after running polygons to lines?
>> Or perhaps there is a cmpletely different way to accomplish the same goal:
>> modifying the boundaries between polygons.
>> Thanks!
>> L
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Editing-polygons-tp6520668p6526418.html
> Sent from the qgis-user mailing list archive at Nabble.com.
