[Qgis-user] Re: Editing polygons
    jorgepsantos2002
    jorgepsantos2002 at gmail.com
    Tue Jun 28 13:16:20 PDT 2011
Hi Laura,
You must use the *Reshape Feature tool* to edit these features under
topologic rules. Press the right button of mouse to finalize the scretch.
See the video:
http://www.youtube.com/watch?v=XgL2OTpBNaY
Best wishes,
_________________
Jorge Santos
Téc. em Geodésia e Cartografia
http://processamentodigital.blogspot.com/
http://twitter.com/jpsantos2002
Skype: jorgepsantos2002
Laura Guillot wrote:
> I'm trying to reshape polygons of a lancover map, in order to make them to
> be more
> coincident with an overlaid raster image (orthophoto 1:5M).
> If I just move the nodes to the correct position, I create a correct line
> but leave a hole behind: the other
> polygon keeps its line where it was. See a pict here:
>  http://osgeo-org.1803224.n2.nabble.com/file/n6526418/boundaryproblem.jpeg
>  Is there any way I could just move the lines as boundaries?
> I've tried by converting poygons to lines first, but the problem is very
> much the same: it seems like
> there is always a double line, one for each adjacent polygon.
> A possible solution would be having the lines automatically cut into
> segments, each going from one vertex to another.
> And having just one segment for each boundary. Is that possible? Is there
> a
> process to cut into segments after running polygons to lines?
> Or perhaps there is a cmpletely different way to accomplish the same goal:
> modifying the boundaries between polygons.
> Thanks!
> L
> Qgis-user mailing list
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Editing-polygons-tp6520668p6526418.html
Sent from the qgis-user mailing list archive at Nabble.com.
