[Qgis-user] QGIS mapserver performance
Andreas Neumann a.neumann at carto.net
Sun Mar 20 13:13:52 PDT 2011
Hi Stefan,
There are some performance bottlenecks regarding clipping of larger/more
complex polygons. Marco can tell you more.
What exactly do you mean by "rendering straight from postgis"? What
software is rendering straight from Postgis? UMN Mapserver, or what
other renderer? Or your own renderer?
Andreas
On 3/20/11 2:44 PM, Ziegler Stefan wrote:
> Hi
> I have some questions concerning the performance of qgis mapserver: Using layers with a small amount of polygons I do not see a big difference between rendering the same layer straight from postgis and from local qgis mapserver installation. For a layer with some 400'000 polygons it takes approx. 4 seconds from qgis mapserver (even for large scales with only some polygons to render). But it only takes some fractions of a second when the layer is rendered straight from postgis (and growing with smaller scales ->  more polyons).
> Everything is running on a dual core laptop. So there should be no big download bottleneck. No special styles are applied to the layers (just a simple fill and an outline). Are there some requests in addition to "GetMap"? Or what's responsible for this big difference?
> regards
> Stefan
> Mit freundlichem Gruss
> Stefan Ziegler
> Leiter amtliche Vermessung
> Amt für Geoinformation
> Rötistrasse 4
> 4501 Solothurn
> 032 627 75 96
> Qgis-user mailing list
