AW: Re: [Qgis-user] QGIS mapserver performance
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Mon Mar 21 00:38:49 PDT 2011
Hi Andi
> What exactly do you mean by "rendering straight from postgis"? What
> software is rendering straight from Postgis? UMN Mapserver, or what
> other renderer? Or your own renderer?
No, "straight from postgis" means adding the layer in QGIS from postgis.
I save this qgis project and make it available as WMS. Since there is
only QGIS (as renderer) involved I thought there would not be a big
performance difference. Ok, there is apache who is handling the cgi
request but that won't take 4 seconds.
> There are some performance bottlenecks regarding clipping of
> larger/more
> complex polygons. Marco can tell you more.
I don't think it's a clipping issue since it's fast when adding the same
layer 'straight from postgis' :) So there must be some additional work
when making a detour.
regards
Stefan
> Andreas
> On 3/20/11 2:44 PM, Ziegler Stefan wrote:
> > Hi
> > I have some questions concerning the performance of qgis
> mapserver: Using layers with a small amount of polygons I do
> not see a big difference between rendering the same layer
> straight from postgis and from local qgis mapserver
> installation. For a layer with some 400'000 polygons it takes
> approx. 4 seconds from qgis mapserver (even for large scales
> with only some polygons to render). But it only takes some
> fractions of a second when the layer is rendered straight
> from postgis (and growing with smaller scales -> more polyons).
> > Everything is running on a dual core laptop. So there
> should be no big download bottleneck. No special styles are
> applied to the layers (just a simple fill and an outline).
> Are there some requests in addition to "GetMap"? Or what's
> responsible for this big difference?
> > regards
> > Stefan
> > Mit freundlichem Gruss
> > Stefan Ziegler
> > Leiter amtliche Vermessung
> > Amt für Geoinformation
> > Rötistrasse 4
> > 4501 Solothurn
> > 032 627 75 96
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110321/501e2ae6/attachment.html>
