[Qgis-user] How to make an hyperlink to a multimedia object in attribute table
jr.morreale at enoreth.net
Fri May 6 01:52:17 PDT 2011
On Fri, 6 May 2011 10:25:51 +0200, Christophe TUFFERY wrote:
> Hi,
> I’m looking to put an hyperlink in a field of an attribute table to
> be able
> to open an external multimedia file (image, video, etc.) by cliking
> on the
> entity and open the multimedia object in another window.
> Does someone have any idea about how to do that or is there any
> existing
> plugin on that topic ?
> Thank you.
Hi Christophe,
There is a short answer, ask more questions if needed.
In QGIS 1.6, you have two main ways of using a field refering to
multimedia file :
- use an action that will open a specific application, this can be
defined in the properties of the layer (see p.74 of the fr manual) and
there could be several different actions for one layer
- use the evis plugin (see p.143)
If you're interested in QGIS, there will be workshops held at the
Rencontres SIG La Lettre the 18 and 19 May.
Regards,
MORREALE Jean Roc
