[Qgis-user] How to make an hyperlink to a multimedia object inattribute table
Christophe TUFFERY christophe.tuffery at inrap.fr
Fri May 6 02:41:50 PDT 2011
Hi Jean-Roc,
Thank you for your answer.
I already tried the first way you mentioned but it doesn't seem to work.
I'm gonna try the second way using eVis... and reading once more the manual
I hope to be successful anyway.
I will participate to Rencontres SIG La Lettre but only the first day May
17...
Hope to meet you there maybe or to here from you anyway on this list or
elsewhere.
Christophe TUFFERY
Ingénieur de recherche
Institut national de recherches archéologiques préventives
Direction Scientifique et Technique / Service Méthodes et Qualité
7, rue de Madrid 75008 PARIS
Tél.: 01-40-08-81-03 / Fax : 01-43-87-18-73
Courriel : christophe.tuffery at inrap.fr
Site Web : www.inrap.fr
-----Message d'origine-----
De : qgis-user-bounces at lists.osgeo.org
[mailto:qgis-user-bounces at lists.osgeo.org] De la part de
jr.morreale at enoreth.net
Envoyé : vendredi 6 mai 2011 10:52
À : qgis-user at lists.osgeo.org
Objet : Re: [Qgis-user] How to make an hyperlink to a multimedia object
inattribute table
 On Fri, 6 May 2011 10:25:51 +0200, Christophe TUFFERY wrote:
> Hi,
> I’m looking to put an hyperlink in a field of an attribute table to
> be able
> to open an external multimedia file (image, video, etc.) by cliking
> on the
> entity and open the multimedia object in another window.
> Does someone have any idea about how to do that or is there any
> existing
> plugin on that topic ?
> Thank you.
 Hi Christophe,
 There is a short answer, ask more questions if needed.
 In QGIS 1.6, you have two main ways of using a field refering to
 multimedia file :
 - use an action that will open a specific application, this can be
 defined in the properties of the layer (see p.74 of the fr manual) and
 there could be several different actions for one layer
 - use the evis plugin (see p.143)
 If you're interested in QGIS, there will be workshops held at the
 Rencontres SIG La Lettre the 18 and 19 May.
 Regards,
 MORREALE Jean Roc
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
