[Qgis-user] Re: Problem with big tiff
Alex Mandel
tech_dev at wildintellect.com
Tue May 17 13:47:02 PDT 2011
That error message seems to have some good clues. Did you recently run
ubuntu's update tool?
I would open synaptic and go the the libtiff package and see which
versions are available to you. I wonder if you self compiled or grabbed
a gdal version that wasn't from ubuntu or ubuntugis, so check what
options you have for the libgdal package.
Note: Ubuntugis just pushed QGIS 1.6 built against GDAL 1.8 if you want
to try that.
I checked both my 32 and 64 bit 10.04 installs and my libtiff is from
lucid-updates and is version 3.9.2-2 which works fine with libgdal 1.8
or 1.7 from ubuntugis.
Thanks,
Alex
On 05/17/2011 07:13 AM, Hugo wrote:
> Hi all,
> Thanks for your comments. Edward, thanks for you directions but i really
> need to solve this issue and moreover i really enjoy QGIS/GRASS, and so, i
> want to keep up with it. The problem now is that i have several projects
> saved that no longer work with raster files (it really doesn't matter what
> size they have). When each project starts loading, i can see all the
> vectorial files being loaded correctly. But as soon as it gets to load any
> type of raster file QGIS just crashes ans shuts down.
> Launching QGIS from the terminal has give me the clue to what is wrong: the
> problem is with my libtiff version. I can see that i have libtiff 4.0
> installed but QGIS is looking for libtiff3 (exactly what Giovanni has
> pointed out).
> Here is the terminal output:
> Error:
> GDAL Error 1: WARNING ! libtiff version mismatch : You're linking
> against libtiff 3.X but GDAL has been compiled against libtiff >= 4.0.0
> So my question is how can i fix this?
> Kind regards,
> Hugo
> On Tue, May 17, 2011 at 1:38 PM, Giovanni Manghi
> <giovanni.manghi at gmail.com>wrote:
>> On Tue, 2011-05-17 at 12:45 +0100, Hugo wrote:
>>> Just to give software context i'm on Ubuntu 10.10 64 bits, using Qgis
>>> 1.6 and GDAL 1.7.
>> Hi Hugo,
>> here with Ubuntu 10.04 32bit and the ubuntugis repository (qgis 1.6) no
>> problems.
>> I added a bunch of overviews before opening the raster file, in any case
>> no crashes.
>> On the other hand I have problems opening rasters (not only yours) if I
>> upgrade to trunk with the nightly builds repository. But this is
>> probably caused by a mix of libraries from the standard ubuntu
>> repository and the ubuntugis one.
>> Cheers
>> -- Giovanni --
