[Qgis-user] Re: Problem with big tiff
Mayeul Kauffmann mayeul.kauffmann at free.fr
Tue May 17 14:13:52 PDT 2011
Hi Alex,
Thanks a lot! Yes you point to two of my problems, I had first problem
with one of my qgis and another with another qgis:
1) The problem I cannot solve is to compile myself qgis 1.7.0rc knowing
that the gdal I have was upgraded to 1.8.0. Could you please tell me if
you know how to switch back to get gdal 1.7.0 and compile against it?
As I wrote earlier, I detailed the error messages and pointed to my
install script in qgis-developer list, here:
http://osgeo-org.1803224.n2.nabble.com/gdal-1-8-0-no-tiff-support-anymore-in-Ubuntu-11-04-Natty-tc6365327.html
2) The other problem that I somehow solved: I compiled one version a few
weeks ago against gdal 1.7.0; when updating to gdal 1.8.0, I was
proposed to remove  gdal 1.7.0, I did it, which broke this qgis (I could
not find back the right package again; I copied libgdal1.7.0.so.1 from
another machine which is still on Ubuntu 10.10, this solves the issue)
Thanks a lot for your support!
Mayeul
Le mardi 17 mai 2011 à 13:47 -0700, Alex Mandel a écrit :
> That error message seems to have some good clues. Did you recently run
> ubuntu's update tool?
> I would open synaptic and go the the libtiff package and see which
> versions are available to you. I wonder if you self compiled or grabbed
> a gdal version that wasn't from ubuntu or ubuntugis, so check what
> options you have for the libgdal package.
> Note: Ubuntugis just pushed QGIS 1.6 built against GDAL 1.8 if you want
> to try that.
> I checked both my 32 and 64 bit 10.04 installs and my libtiff is from
> lucid-updates and is version 3.9.2-2 which works fine with libgdal 1.8
> or 1.7 from ubuntugis.
> Thanks,
> Alex
> On 05/17/2011 07:13 AM, Hugo wrote:
> > Hi all,
> > Thanks for your comments. Edward, thanks for you directions but i really
> > need to solve this issue and moreover i really enjoy QGIS/GRASS, and so, i
> > want to keep up with it. The problem now is that i have several projects
> > saved that no longer work with raster files (it really doesn't matter what
> > size they have). When each project starts loading, i can see all the
> > vectorial files being loaded correctly. But as soon as it gets to load any
> > type of raster file QGIS just crashes ans shuts down.
> > Launching QGIS from the terminal has give me the clue to what is wrong: the
> > problem is with my libtiff version. I can see that i have libtiff 4.0
> > installed but QGIS is looking for libtiff3 (exactly what Giovanni has
> > pointed out).
> > Here is the terminal output:
> > Error:
> >     GDAL Error 1: WARNING ! libtiff version mismatch : You're linking
> > against libtiff 3.X but GDAL has been compiled against libtiff >= 4.0.0
> > So my question is how can i fix this?
> > Kind regards,
> > Hugo
> > On Tue, May 17, 2011 at 1:38 PM, Giovanni Manghi
> > <giovanni.manghi at gmail.com>wrote:
> >> On Tue, 2011-05-17 at 12:45 +0100, Hugo wrote:
> >>> Just to give software context i'm on Ubuntu 10.10 64 bits, using Qgis
> >>> 1.6 and GDAL 1.7.
> >> Hi Hugo,
> >> here with Ubuntu 10.04 32bit and the ubuntugis repository (qgis 1.6) no
> >> problems.
> >> I added a bunch of overviews before opening the raster file, in any case
> >> no crashes.
> >> On the other hand I have problems opening rasters (not only yours) if I
> >> upgrade to trunk with the nightly builds repository. But this is
> >> probably caused by a mix of libraries from the standard ubuntu
> >> repository and the ubuntugis one.
> >> Cheers
> >> -- Giovanni --
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110517/0f1bfd0e/attachment.html>
