[Qgis-user] QGIS Actions and relative path
Peter Wells
wellsp at faunalia.co.uk
Wed May 18 08:19:25 PDT 2011
You guys,
I'm having similar frustrations with the lack of relative path support.
At some point, it'd be good to have a checkbox in the actions
configuration section that said something like "Use Shapefile's directory
as root of relative paths"
Pete
> When I use relative paths, for spatial files or for a actions, it don't
> work when I open the QGis project in Quantum GIS. It only works, when I
> start the project with a double click on the project file (.qgs).
> But then it's no problem to use relative paths with a action.
> I'm using QGis 1.6 and Windows XP.
> I save the project, open it with a editor, change the absolute paths into
> relative, and if i then start the project with double click it works.
> Asmus
> -------- Original-Nachricht --------
>> Datum: Wed, 18 May 2011 14:28:46 +0200
>> Von: Andreas Neumann <a.neumann at carto.net>
>> An: qgis-user at lists.osgeo.org
>> Betreff: Re: [Qgis-user] QGIS Actions and relative path
>> You could probably do this with python. I am not entirely sure if it
>> works, but there are python actions. The python action gets a reference
>> to the feature - maybe - if you can access the project file from
>> python,
>> there is a QgsProject::readPath
>> (http://doc.qgis.org/head/classQgsProject.html#cfdc9943dcba296540309f89e93a9f60).
>> This way you can detect the absolute path of the project file and build
>> your path as you like.
>> But you are right, it would be convenient if file reference could be
>> stored relative to the project file.
>> Maybe Jürgen has some idea.
>> Andreas
>> On Wed, 18 May 2011 04:55:44 -0700 (PDT), iomeneandrei wrote:
>> > Dear all,
>> > I'm using QGIS 1.6 for windows and I'm using a simple General Action:
>> > cmd /c %MyField
>> > I'm using it to open some pdf files. In MyField field I have the
>> > absolute
>> > path of my files. Is there a way to use a path relative to the QGIS
>> > project?
>> > It would be fantastic to use (in example) this kind of QGIS project
>> > structure:
>> > - /root of the project
>> > -- /raster spatial file
>> > -- /vector spatial file
>> > -- /file called from actions
>> > - ProjectFile.qgis
>> > I know that QGIS can use relative path for spatial files, but I do
>> > not know
>> > if it's possible to use relative path within actions.
>> > Is there a variable that maps the absolute path of the project file?
>> > If it
>> > does exist I could write my Action in this way:
>> > cmd /c $PathOfProjectFile %MyFieldWithRelativePath
>> > Thank you,
>> > a
>> > Andrea Borruso
>> > email: aborruso at tin.it
>> > website: http://blog.spaziogis.it
>> > my 2.0 life: http://aborruso.spaziogis.it
>> > feed: http://feeds2.feedburner.com/Tanto
>> > 38° 7' 48" N, 13° 21' 9" E
>> > View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/QGIS-Actions-and-relative-path-tp6377487p6377487.html
>> > Sent from the qgis-user mailing list archive at Nabble.com.
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
> NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> Jetzt informieren: http://www.gmx.net/de/go/freephone
