[Qgis-user] Re: Azimuth and Distance Plugin (was Re: your old qgis plugins)
Darren Cope
darrencope at gmail.com
Wed May 18 10:35:52 PDT 2011
Thanks Fred--the inconsistent entry is a problem for sure, and perhaps part
of why I'm getting confused! This one in particular does not close--like you
said, many of them do not. However, as long as it's pretty close...
Darren Cope
http://darrencope.com
http://dmcope.freeshell.org
2011/5/18 Fred LaPlante <flaplante at flos-inc.com>
> OK, looks like we are both talking about the same 'English' system of metes
> & bounds. Your parcel looks just like mine. And none of the bearings look
> nearly precise enough to guarantee closure. The most conspicuous absence is
> lack of a True vs magnetic notation. For Canada that can be a killer - and
> magnetic can easily vary 40min in ten years. Also I see that the surveyor
> didn't enter the bearings in a consistent way as he walked around the
> property so the bearings have to be reversed manually, or a negative sign
> used.
> Anyway, I'll get a copy of qGis running and see what I can do with your
> drawing.
> Fred
> On 5/18/2011 1:19 PM, Darren Cope wrote:
>> Thanks Fred,
>> I've (re)attached the image example--the coordinates we deal with in
>> Ontario (and most of Canada) seem to (almost all) come in the format shown
>> in my attachment. It doesn't make a whole lot of sense to me from a
>> 'usability' standpoint, but...
>> Darren Cope
>> 2011/5/18 Fred LaPlante <flaplante at flos-inc.com <mailto:
>> flaplante at flos-inc.com>>
>> Wow! voices from the past.
>> Darren,
>> I haven't done anything with qGIS for over a year now. But this
>> does remind me I need to get back to it again just to catch up on
>> some things here on my desk. Unfortunately I 'upgraded?' my
>> computer system to Windows7 since then and qGIS didn't make the
>> transfer (though the data did make it!). So I will have to answer
>> your questions from memory.
>> I think Mauricio got it all right. Here in Maine, USA, land
>> boundaries in property deeds and maps are given in 'metes and
>> bounds' that is nnn.nn feet North/South xxdeg East or West. (For
>> example 950.5 feet N 30deg 45Min 20Sec East). So what I would do
>> is to establish a starting point from whatever corner I could pin
>> down on a map and then 'walk' around the property entering the
>> distance and heading as given on the deed or property map. I have
>> done this with the Az & Dist plugin for many land parcels in my
>> home town. But having said that let me add that getting 'closure'
>> is seldom achieved. I found the accuracy of the property deeds or
>> maps even with signatures and seals of licensed surveyors was very
>> poor. Sometime I got definitions like "900feet N 40deg E (plus or
>> minus)". It seems only the surveyors markers mean anything and the
>> legal description is only a guide to help find them. Surveyors
>> tell me "Here in Maine everyone knows how to get to their property
>> but no one really know where it is."
>> Unfortunately your plan didn't get to me so I can't be sure just
>> what the difficulty is. If you could send me a copy, I will try to
>> enter it into qGIS and see what happens. Perhaps a bug has gotten
>> into the code since I last used it. But I still have my original
>> plugin code so we should be able to get things working again.
>> Here is an extract from some instructions I wrote for the local
>> town government. Perhaps this will be helpful.
>> Fred LaPlante
>> Mercer, ME, USA
>> 5.4 Survey Data
>> Deeds normally provide a list of bearing and distance from a
>> starting point around a property boundary in a consistent
>> direction until returning to the start. The process describe here
>> should accept most property descriptions as written.
>> Survey maps may be consistent as well, but sometimes a direction
>> my appear as a ‘back bearing’ due to the nature of the survey.
>> These can be handled with the addition of a minus ‘-‘ sign at the
>> beginning of a bearing.Failure to catch this detail can produce
>> some fascinating, but useless,drawings.
>> 1. Open or create a layer for your new feature.
>> 2. Use properties to set transparency to 50-75%
>> 3. Enable editing of the layer.
>> 4. Open the ‘Azimuth & Distance’ Plugin.
>> 5. Verify both the Layer and Coordinate System (CRS) shown are
>> correct.
>> 6. For most surveys, Boundary type survey is correct.
>> 7. Select North type that applies (enter magnetic declination if
>> appropriate)
>> 8. Select Distance units. In USA this will probably be feet.
>> 9. Select Angle Type: Azimuth is a compass heading, Bearing is of the
>> form N xx deg E
>> 10. Click ‘Capture from Map’
>> 11. Move mouse to location of starting point on base map.
>> 12. Under ‘Next Vertex’ enter direction and distance from survey
>> or deed.
>> 13. Click ‘Add to Bottom’.
>> 14. Repeat above 2 steps as needed.
>> 15. Click ‘Export List’ to save your entries for a later time.
>> 16. Click Draw.
>> On 5/18/2011 11:14 AM, Maurício de Paulo wrote:
>> Hi Darren,
>> I haven't worked on the plugin for a long time now.
>> The terms are about what angle is given to the plugin.
>> Bearing is measured from a given direction but with 180
>> degrees for each side (Ex.: 90e means right. 90w means left).
>> Azimuth is measured from a given direction but with 360
>> degrees clockwise. (Ex.: 90 means right. 270 means left)
>> The polar/Radial means that the angles area going to be
>> centered on the point given. It's usefull when you did angular
>> measures from the same point. It's used when you measure
>> angles and distances from a single point to draw a curve.
>> The Boundary means that the angles are relative to the last
>> point you measured. It's commonly used in the descriptive
>> documents when the next point is calculated with angle and
>> distance from the current point.
>> I think Fred can help more with the meaning of each term as
>> many of them I couldn't translate to a common english idea.
>> Fred Laplante is also involved in the project and implemented
>> many of these concepts.
>> Best regards,
>> Mauricio de Paulo
>> 2011/5/18 Darren Cope <darrencope at gmail.com
>> <mailto:darrencope at gmail.com> <mailto:darrencope at gmail.com
>> <mailto:darrencope at gmail.com>>>
>> Hi Mauricio,
>> I'm curious if you are still working on the Azimuth and
>> Distance
>> Plug in for QGIS? I am back to it again, and still having
>> difficulties. I would like to be able to help you test if
>> you are
>> still developing. I have an example (attached) of a plan that
>> needs to be entered using the distances and bearings shown (in
>> that exact format). How would I go about doing so? I have tried
>> every possible combination that makes any sense to me! I'm
>> fairly
>> certain I just don't fully understand the implications of the
>> "Polar/Radial" and "Boundary", and "Azimuth" and "Bearing"
>> settings. Perhaps you could explain?
>> Cheers,
>> Darren Cope
>> 2009/11/11 Darren Cope <darrencope at gmail.com
>> <mailto:darrencope at gmail.com <mailto:darrencope at gmail.com>>>
>> Hi Mauricio,
>> I'm not 100% sure what is going on with the precision. I
>> suspect the snapping feature will solve this, as the
>> difference is quite small. I zoomed in to 2:1 (e.g. as
>> far as
>> I could) and clicked as close as I possibly could to a
>> corner
>> vertex, and then when I drew my feature, it doesn't line up
>> (although the difference is minute in terms of actual
>> distance)
>> I guess I'm still not 100% clear on how the coordinates are
>> entered. What does the 'zenith' column mean? I have a
>> lot of
>> plans that give angles relative to north or south (so
>> they are
>> displayed as Nxxdxx'xx"W or Sxxdxx'xx"E for example). I can
>> convert these to a 360-based azimuth, but it would be
>> nice to
>> be able to enter these without doing any prior conversions.
>> It looks like the zooming issue is fixed now!
>> Thanks for all of your work on this--please let me know
>> if I
>> can provide any further information or testing for you.
>> Cheers,
>> Darren Cope
>> 2009/11/7 Maurício de Paulo <mauricio.dev at gmail.com
>> <mailto:mauricio.dev at gmail.com>
>> <mailto:mauricio.dev at gmail.com <mailto:mauricio.dev at gmail.com>>>
>> Ok, thanks for the ideas. But could explain some of
>> them
>> to me?
>> What happened with the precision of the starting point?
>> I've made some tests here and the precision should
>> be ok.
>> I've made a teste with 0,0,0 and it drew fine.
>> Could you
>> tell me how to reproduce the bug?
>> The snapping feature is my main priority now. I
>> think this
>> is a great improvement.
>> DMS should be second in the list. But actually I
>> need some
>> inputs on how is best entered a coordinate. We're
>> talking
>> about azimuth here. And a DMS should have 3 numbers.
>> Something like 10o14'52'' is possible and easy for the
>> user. Is it ok?
>> About the much larger extent... Hum... Fixed on zoom to
>> selected feature. I think that should solve it.
>> Gratefully
>> Maurício de Paulo
>> -- Mauricio de Paulo
>> Engenheiro Cartografo
>> MapeandoOBrasil <http://mapeandoobrasil.blogspot.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110518/fab06de7/attachment.html>
