[Qgis-user] Re: Azimuth and Distance Plugin (was Re: your old qgis	plugins)
    Fred LaPlante
    flaplante at flos-inc.com
    Wed May 18 12:40:21 PDT 2011
I just tried out the map you sent me and the Az & Distance plugin worked
just fine for me. the closure seems pretty good though I didn't zoom in
to check.  I did switch the n/s and E/W designations on 3 edges so that
all bearings were toward the next corner (moveing clockwise aroind the
map). other that that and being careful of my typing, I did nothing but
enter thee data.
I did specify 'boundary',  'bearing', and 'feet' for options. And I did
have CRS set to NAD83. Also I did save (or 'export') the data to a test
file and was able later to retrieve it to correct an error.
So the plug-in works for me in version 1.6.0.  I suspect your problem
was mainly in making the bearings consistent from a boundary walker's
perspective.
Fred
On 5/18/2011 1:33 PM, Fred LaPlante wrote:
> OK, looks like we are both talking about the same 'English' system of
> metes & bounds.  Your parcel looks just like mine. And none of the
> bearings look nearly precise enough to guarantee closure. The most
> conspicuous absence is lack of a True vs magnetic notation. For Canada
> that can be a killer - and magnetic can easily vary 40min in ten
> years. Also I see that the surveyor didn't enter the bearings in a
> consistent way as he walked around the property so the bearings have
> to be reversed manually, or a negative sign used.
> Anyway, I'll get a copy of qGis running and see what I can do with
> your drawing.
> Fred
> On 5/18/2011 1:19 PM, Darren Cope wrote:
>> Thanks Fred,
>> I've (re)attached the image example--the coordinates we deal with in
>> Ontario (and most of Canada) seem to  (almost all) come in the format
>> shown in my attachment. It doesn't make a whole lot of sense to me
>> from a 'usability' standpoint, but...
>> Darren Cope
>> http://darrencope.com
>> http://dmcope.freeshell.org
>> 2011/5/18 Fred LaPlante <flaplante at flos-inc.com
>> <mailto:flaplante at flos-inc.com>>
>>     Wow! voices from the past.
>>     Darren,
>>     I haven't done anything with qGIS for over a year now. But this
>>     does remind me I need to get back to it again just to catch up on
>>     some things here on my desk. Unfortunately I 'upgraded?' my
>>     computer system to Windows7 since then and qGIS didn't make the
>>     transfer (though the data did make it!). So I will have to answer
>>     your questions from memory.
>>     I think Mauricio got it all right. Here in Maine, USA, land
>>     boundaries in property deeds and maps are given in 'metes and
>>     bounds' that is nnn.nn feet North/South xxdeg East or West. (For
>>     example 950.5 feet N 30deg 45Min 20Sec East). So what I would do
>>     is to establish a starting point from whatever corner I could pin
>>     down on a map and then 'walk' around the property entering the
>>     distance and heading as given on the deed or property map. I have
>>     done this with the Az & Dist plugin for many land parcels in my
>>     home town. But having said that let me add that getting 'closure'
>>     is seldom achieved. I found the accuracy of the property deeds or
>>     maps even with signatures and seals of licensed surveyors was very
>>     poor. Sometime I got definitions like "900feet N 40deg E (plus or
>>     minus)". It seems only the surveyors markers mean anything and the
>>     legal description is only a guide to help find them. Surveyors
>>     tell me "Here in Maine everyone knows how to get to their property
>>     but no one really know where it is."
>>     Unfortunately your plan didn't get to me so I can't be sure just
>>     what the difficulty is. If you could send me a copy, I will try to
>>     enter it into qGIS and see what happens. Perhaps a bug has gotten
>>     into the code since I last used it. But I still have my original
>>     plugin code so we should be able to get things working again.
>>     Here is an extract from some instructions I wrote for the local
>>     town government. Perhaps this will be helpful.
>>     Fred LaPlante
>>     Mercer, ME, USA
>>         5.4 Survey Data
>>     Deeds normally provide a list of bearing and distance from a
>>     starting point around a property boundary in a consistent
>>     direction until returning to the start. The process describe here
>>     should accept most property descriptions as written.
>>     Survey maps may be consistent as well, but sometimes a direction
>>     my appear as a ‘back bearing’ due to the nature of the survey.
>>     These can be handled with the addition of a minus ‘-‘ sign at the
>>     beginning of a bearing.Failure to catch this detail can produce
>>     some fascinating, but useless,drawings.
>>      1. Open or create a layer for your new feature.
>>      2. Use properties to set transparency to 50-75%
>>      3. Enable editing of the layer.
>>      4. Open the ‘Azimuth & Distance’ Plugin.
>>      5. Verify both the Layer and Coordinate System (CRS) shown are
>>     correct.
>>      6. For most surveys, Boundary type survey is correct.
>>      7. Select North type that applies (enter magnetic declination if
>>         appropriate)
>>      8. Select Distance units. In USA this will probably be feet.
>>      9. Select Angle Type: Azimuth is a compass heading, Bearing is
>> of the
>>         form N xx deg E
>>      10. Click ‘Capture from Map’
>>      11. Move mouse to location of starting point on base map.
>>      12. Under ‘Next Vertex’ enter direction and distance from survey
>>     or deed.
>>      13. Click ‘Add to Bottom’.
>>      14. Repeat above 2 steps as needed.
>>      15. Click ‘Export List’ to save your entries for a later time.
>>      16. Click Draw.
>>     On 5/18/2011 11:14 AM, Maurício de Paulo wrote:
>>         Hi Darren,
>>         I haven't worked on the plugin for a long time now.
>>         The terms are about what angle is given to the plugin.
>>         Bearing is measured from a given direction but with 180
>>         degrees for each side (Ex.: 90e means right. 90w means left).
>>         Azimuth is measured from a given direction but with 360
>>         degrees clockwise. (Ex.: 90 means right. 270 means left)
>>         The polar/Radial means that the angles area going to be
>>         centered on the point given. It's usefull when you did angular
>>         measures from the same point. It's used when you measure
>>         angles and distances from a single point to draw a curve.
>>         The Boundary means that the angles are relative to the last
>>         point you measured. It's commonly used in the descriptive
>>         documents when the next point is calculated with angle and
>>         distance from the current point.
>>         I think Fred can help more with the meaning of each term as
>>         many of them I couldn't translate to a common english idea.
>>         Fred Laplante is also involved in the project and implemented
>>         many of these concepts.
>>         Best regards,
>>         Mauricio de Paulo
>>         2011/5/18 Darren Cope <darrencope at gmail.com
>> <mailto:darrencope at gmail.com> <mailto:darrencope at gmail.com
>> <mailto:darrencope at gmail.com>>>
>>            Hi Mauricio,
>>            I'm curious if you are still working on the Azimuth and
>>         Distance
>>            Plug in for QGIS? I am back to it again, and still having
>>            difficulties. I would like to be able to help you test if
>>         you are
>>            still developing. I have an example (attached) of a plan that
>>            needs to be entered using the distances and bearings shown
>> (in
>>            that exact format). How would I go about doing so? I have
>> tried
>>            every possible combination that makes any sense to me! I'm
>>         fairly
>>            certain I just don't fully understand the implications of the
>>            "Polar/Radial" and "Boundary", and "Azimuth" and "Bearing"
>>            settings. Perhaps you could explain?
>>            Cheers,
>>            Darren Cope
>>            2009/11/11 Darren Cope <darrencope at gmail.com
>> <mailto:darrencope at gmail.com <mailto:darrencope at gmail.com>>>
>>                Hi Mauricio,
>>                I'm not 100% sure what is going on with the precision. I
>>                suspect the snapping feature will solve this, as the
>>                difference is quite small. I zoomed in to 2:1 (e.g. as
>>         far as
>>                I could) and clicked as close as I possibly could to a
>>         corner
>>                vertex, and then when I drew my feature, it doesn't
>> line up
>>                (although the difference is minute in terms of actual
>>         distance)
>>                I guess I'm still not 100% clear on how the
>> coordinates are
>>                entered. What does the 'zenith' column mean? I have a
>>         lot of
>>                plans that give angles relative to north or south (so
>>         they are
>>                displayed as Nxxdxx'xx"W or Sxxdxx'xx"E for example).
>> I can
>>                convert these to a 360-based azimuth, but it would be
>>         nice to
>>                be able to enter these without doing any prior
>> conversions.
>>                It looks like the zooming issue is fixed now!
>>                Thanks for all of your work on this--please let me know
>>         if I
>>                can provide any further information or testing for you.
>>                Cheers,
>>                Darren Cope
>>                2009/11/7 Maurício de Paulo <mauricio.dev at gmail.com
>> <mailto:mauricio.dev at gmail.com>
>> <mailto:mauricio.dev at gmail.com <mailto:mauricio.dev at gmail.com>>>
>>                    Ok, thanks for the ideas. But could explain some of
>>         them
>>                    to me?
>>                    What happened with the precision of the starting
>> point?
>>                    I've made some tests here and the precision should
>>         be ok.
>>                    I've made a teste with 0,0,0 and it drew fine.
>>         Could you
>>                    tell me how to reproduce the bug?
>>                    The snapping feature is my main priority now. I
>>         think this
>>                    is a great improvement.
>>                    DMS should be second in the list. But actually I
>>         need some
>>                    inputs on how is best entered a coordinate. We're
>>         talking
>>                    about azimuth here. And a DMS should have 3 numbers.
>>                    Something like 10o14'52'' is possible and easy for
>> the
>>                    user. Is it ok?
>>                    About the much larger extent... Hum... Fixed on
>> zoom to
>>                    selected feature. I think that should solve it.
>>                    Gratefully
>>                    Maurício de Paulo
>>         --         Mauricio de Paulo
>>         Engenheiro Cartografo
>>         MapeandoOBrasil <http://mapeandoobrasil.blogspot.com>
