[Qgis-user] Processing of Groundwater Databases witkh QGIS
mcav8r2003 at yahoo.com mcav8r2003 at yahoo.com
Wed May 25 18:16:25 PDT 2011
Sent from my LG phone
Christine Schmidt <c.schmidt at geoTguide.de> wrote:
>Hi Giovanni,
>thanks for your hints !
>Most of the mentioned methods I know more or less.
>Important for the evaluation of an interpolation's reliability is a review
>of the variogram and some statistical values. This should be also possible
>in QGIS, as far as I could see until now - if not directly, then via R or a
>GRASS plugin.
>This would be more than I have now in a proprietary groundwater database
>management system with integrated interpolation functionality. That's why I
>am looking for an alternative processing option.
>I am about to develop a subject for a master thesis in geoinformatics. First
>of all I want to check what is present in the field in order to decide what
>I can manage and contribute to proceed in this application field.
>tanto gracie e saluti,
>Christine
>-----Ursprüngliche Nachricht-----
>Von: "G. Allegri" <giohappy at gmail.com>
>Gesendet: 26.05.2011 00:21:46
>An: "Christine Schmidt" <c.schmidt at geotguide.de>
>Betreff: Re: Re: [Qgis-user] Processing of Groundwater Databases with QGIS
>>Spatial interpolation can be realized in many ways. There are lot
>>different methods, which fit different needs.
>> - Inverse Distance Weighting (IDW)
>> - B-Splines
>> - Kriging
>> - Statistical simulations
>> - etc.
>>As you know, none of them is correct without a knowledge of the
>>groundwater structure and stratygraphy. Anyway, in general, for this
>>kind of elaborations, IDW and kriging are mostly used.
>>AFAIK, QGis can do IDW [1], while the other methods will need external
>>softwares like GRASS and R. In this case the related QGis plugins can
>>be used.
>>If you can give us more details on the kind of interpolation you nedd,
>>we could give more advices.
>>Giovanni
>>[1]
>>http://www.gistutor.com/quantum-gis/20-intermediate-quantum-gis-tutorials/51-inverse-distance-weighting-idw-interpolation-using-qgis.html
>>2011/5/25 Christine Schmidt <c.schmidt at geotguide.de>:
>>> Hi Bob,
>>> thanks for the feed back.
>>> Do you capture groundwater level data in boreholes and in monitoring
>>> wells
>>> with this plugin to store it in a database? Sounds interesting although I
>>> wasn't searching exactly for that.
>>> Want to process data of existing groundwater databases with QGIS.
>>> Processing
>>> means precisely the interpolation of groundwater level data and
>>> laboratory
>>> analysis data for groundwater monitoring wells.
>>> I am checking what is already present in this field and what could
>>> perhaps
>>> be contributed for an efficient workflow.
>>> Regards,
>>> Christine
>>> ________________________________
>>> Von: "Bob and Deb" <bobdebm at gmail.com>
>>> Gesendet: 25.05.2011 18:31:57
>>> Betreff: Re: [Qgis-user] Processsing of Groundwater Databases with QGIS
>>> Hi Christine,
>>> I've been working on a borehole data entry plugin. We are using it to
>>> record historical high groundwater for use in liquefaction zone mapping.
>>> Are you looking for this kind of use cases?
>>> Regards,
>>> Bob
>>> On May 25, 2011 9:03 AM, "Christine Schmidt" <c.schmidt at geotguide.de>
>>> wrote:
>>>> Dear QGIS community,
>>>> would like to post my first question in this mailing list as follows:
>>>> a.. Does anybody know something about a project or use case of
>>>> processing
>>>> groundwater databases with QGIS, exspecially in order to make
>>>> interpolations
>>>> of point data (well data) ?
>>>> Got to know something similar in the context of GRASS
>>>> (Carrera-Hernandez,
>>>> 2007). But what about QGIS in this application field ?
>>>> Thanks a lot for any feedback,
>>>> warm regards,
>>>> Christine
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>___________________________________________________________
>Schon gehört? WEB.DE hat einen genialen Phishing-Filter in die
>Toolbar eingebaut! http://produkte.web.de/go/toolbar
