[Qgis-user] RE: RE: rpy2, R and QGIS
Ekvinay Sayaraj
ekvinay at live.com
Sun May 29 22:08:04 PDT 2011
Dear Maxime and all,
I have changed to use R.2.11.0 as you advised, now I could link ManageR.
Thanks very much
best regards
Ekvinay
> From: qgis-user-request at lists.osgeo.org
> Subject: Qgis-user Digest, Vol 63, Issue 60
> To: qgis-user at lists.osgeo.org
> Date: Wed, 25 May 2011 12:00:23 -0400
> Send Qgis-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Re: local TMS in qgis (Jeff Ruby)
> 2. Join my network on LinkedIn
> (Manuel Sp?nola Parallada via LinkedIn)
> 3. rpy2, R and QGIS (Ekvinay Sayaraj)
> 4. RE: rpy2, R and QGIS (Maxime demers)
> Message: 1
> Date: Wed, 25 May 2011 08:31:20 -0400
> From: Jeff Ruby <jgr007 at gmail.com>
> Subject: [Qgis-user] Re: local TMS in qgis
> Message-ID: <BANLkTi=dy8ukE_6DUscNoxiKFFTK4q26nA at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Maning,
> I've been trying to do the same thing, with limited success. QGIS
> supports all gdal formats so you should be able to use to OGC WMS
> format (http://www.gdal.org/frmt_wms.html). However, there was a bug
> that prevented that format from reading local files correctly; it
> could only access files from web servers. I believe this bug has been
> fixed in GDAL trunk, but I'm not positive. At any rate, it's probably
> not pushed out into any versions of GDAL that QGIS is using.
> As a work around I tried using HFS (http://www.rejetto.com/hfs/), a
> very simple file server, and adding my TMS cache to that, but I've run
> into problems there too. My TMS will display, but not correctly. The
> output of gdal_translate is also incorrect, so I suspect that it is an
> issue with GDAL, but I'm not positive and I haven't had time to
> thoroughly investigate.
> This doesn't answer your question, but perhaps it will give you some
> ideas to try. Maybe you can figure it out and let me know what you
> did. :) I'm still working on this here and there when I get a chance.
> If I have any success I will post what I did.
> Regards,
> -Jeff
> > Message: 7
> > Date: Wed, 25 May 2011 16:43:27 +0800
> > From: maning sambale <emmanuel.sambale at gmail.com>
> > Subject: [Qgis-user] local TMS in qgis
> > To: qgis-user <qgis-user at lists.osgeo.org>
> > Message-ID: <BANLkTimiO9vso-chJ8ESKDWAj2u1BqbmVA at mail.gmail.com>
> > Content-Type: text/plain; charset=UTF-8
> > How to load a local TMS in QGIS? I created a TMS for an openlayers
> > basemap and overlay. I want to use the same tiles in QGIS. The
> > metadat is in json format.
> > cheers,
> > maning
> > "Freedom is still the most radical idea of all" -N.Branden
> > wiki: http://esambale.wikispaces.com/
> > blog: http://epsg4253.wordpress.com/
> > Qgis-user at lists.osgeo.org
> > End of Qgis-user Digest, Vol 63, Issue 59
> Message: 2
> Date: Wed, 25 May 2011 12:56:24 +0000 (UTC)
> From: Manuel Sp?nola Parallada via LinkedIn <member at linkedin.com>
> Subject: [Qgis-user] Join my network on LinkedIn
> To: Kumaran Narayanaswamy <qgis-user at lists.osgeo.org>
> Message-ID:
> <1769261288.5819982.1306328184664.JavaMail.app at ela4-bed36.prod>
> Content-Type: text/plain; charset="utf-8"
> LinkedIn
> Manuel SpÃnola Parallada requested to add you as a connection on LinkedIn:
> I'd like to add you to my professional network on LinkedIn.
> Accept invitation from Manuel SpÃnola Parallada
> http://www.linkedin.com/e/-c51gla-go4a2mab-5z/IpKrxohiIYGmJTnvcClrvWFid5LqtedzwFEmeUC/blk/I2838450635_2/1BpC5vrmRLoRZcjkkZt5YCpnlOt3RApnhMpmdzgmhxrSNBszYOnPkPdz0Rd3wPe399bStikPx2s7lMbPsSd3gMcPwVej8LrCBxbOYWrSlI/EML_comm_afe/
> View invitation from Manuel SpÃnola Parallada
> http://www.linkedin.com/e/-c51gla-go4a2mab-5z/IpKrxohiIYGmJTnvcClrvWFid5LqtedzwFEmeUC/blk/I2838450635_2/39vdjcSc3kQe3cUcAALqnpPbOYWrSlI/svi/
> (c) 2011, LinkedIn Corporation
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110525/9e0faf9c/attachment-0001.html
> Message: 3
> Date: Wed, 25 May 2011 20:21:41 +0700
> From: Ekvinay Sayaraj <ekvinay at live.com>
> Subject: [Qgis-user] rpy2, R and QGIS
> To: <qgis-user at lists.osgeo.org>
> Message-ID: <SNT131-w56615D7DF49E4E3A4D2650C4740 at phx.gbl>
> Content-Type: text/plain; charset="iso-8859-1"
> Hello everyone,
> my system is Windows 7, I use R.2.12.2 and QGIS 1.6.0, I install ManageR plugin but it instruct that i need at least rpy2 2.1.x alpha 2, i try find it from SOURCEFORGE but the binary is only rpy2 2.0.8. please advise me how should i do? or some of you know where i could download it?
> cheers
> Ek
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110525/0d5ec538/attachment-0001.html
> Message: 4
> Date: Wed, 25 May 2011 14:27:27 +0000
> From: Maxime demers <burton.1 at sympatico.ca>
> Subject: RE: [Qgis-user] rpy2, R and QGIS
> To: <ekvinay at live.com>, <qgis-user at lists.osgeo.org>
> Message-ID: <BAY148-w51E1CB1E524AE677735609BE740 at phx.gbl>
> Hi,
> I would suggest you to use OSGeo4W to install rpy2. You can find rpy2 in the list of libs when you choose a manual install.
> Also, you may have some problem with R.2.12.2 because its not fully compatible with rpy2. I would suggest to try running ManageR with R 2.11.0 or above.
> Good luck and please tell us if you are sucessful
> Maxime
> From: ekvinay at live.com
> Hello everyone,
> cheers
> Ek
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110525/51d2c07c/attachment-0001.html
> End of Qgis-user Digest, Vol 63, Issue 60
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110530/37299ae0/attachment.html>
