[Qgis-user] export as vector graphic
Alex Mandel tech_dev at wildintellect.com
Mon May 30 20:21:49 PDT 2011
PDF Export on Windows (Works on Linux/Mac) is broken (more info
https://trac.osgeo.org/qgis/ticket/3250). SVG does work but I recommend
clipping all your data closer to the extent of the map composer before
exporting.
I usually go to Inkscape as the next step from SVG or PDF and then
output a final PDF from there.
Enjoy,
Alex
On 05/30/2011 12:20 PM, Andreas Neumann wrote:
> Hi Christof,
> Vector export from the print composer to SVG or PDF should work. I
> recommend to use the new symbology engine. That way point symbols are
> kept as vectors in a PDF or SVG output. There are some problems that
> should be resolved in future versions, but in general it works.
> Also make sure you have a recent version (1.7).
> Andreas
> On 05/30/2011 07:19 PM, Christof Kluß wrote:
>> Hi,
>> is it possible to convert shapefiles into a vector format like SVG or
>> PDF? Print and PDF plugin seem to convert the vector data to raster
>> graphics.
>> If not, is there another inexpensive tool that can? So we get scalable
>> PDF files?
>> tia
>> Christof
