[Qgis-user] Swipe functionality
jonathanmoules at warwickshire.gov.uk jonathanmoules at warwickshire.gov.uk
Tue Nov 1 06:15:37 PDT 2011
Thanks both. I was looking in the install directory for a plugins
directory.
I've managed to install it and activate it, but it's not working - the
slider bars are always greyed out; any thoughts as to why. I'm trying to
use it on an ECW and a JP2.
Beyond this, is there an actual swipe-ing plugin or functionality for
QGIS?
Regards,
Jonathan
From:   "Saber Razmjooei" <razmjooeis at faunalia.co.uk>
To:     giovanni.manghi at gmail.com
Cc:     jonathanmoules at warwickshire.gov.uk, "Saber Razmjooei"
<razmjooeis at faunalia.co.uk>, qgis-user at lists.osgeo.org
Date:   01/11/2011 13:05
Subject:        Re: [Qgis-user] Swipe functionality
In Windows XP, it is:
C:\Documents and Settings\YOUR USERNAME\.qgis\python\plugins
>> The documentation I find says to use the "Fetch plugins" functionality
>> for installing, but that requires an internet connection which the
>> QGIS machine doesn't have. Are there manual install instructions?
> unzip the file, and place the resulting folder into the
> ".qgis/python/plugins" one you find in your system (under Windows that
> folder is inside your c:/users/username folder).
> cheers
> -- giovanni --
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111101/a086d3c4/attachment.html>
