[Qgis-user] Swipe functionality
    Giovanni Manghi
    giovanni.manghi at gmail.com
    Tue Nov  1 06:17:29 PDT 2011
I believe the plugin works only with single-band images.
What does exactly this "swipe" functionality?
Cheers
-- Giovanni --
On Tue, 2011-11-01 at 13:15 +0000, jonathanmoules at warwickshire.gov.uk
wrote:
> Thanks both. I was looking in the install directory for a plugins
> directory.
> I've managed to install it and activate it, but it's not working - the
> slider bars are always greyed out; any thoughts as to why. I'm trying
> to use it on an ECW and a JP2.
> Beyond this, is there an actual swipe-ing plugin or functionality for
> QGIS?
> Regards,
> Jonathan
> From:        "Saber Razmjooei" <razmjooeis at faunalia.co.uk>
> To:        giovanni.manghi at gmail.com
> Cc:        jonathanmoules at warwickshire.gov.uk, "Saber Razmjooei"
> <razmjooeis at faunalia.co.uk>, qgis-user at lists.osgeo.org
> Date:        01/11/2011 13:05
> Subject:        Re: [Qgis-user] Swipe functionality
> ______________________________________________________________________
> In Windows XP, it is:
> C:\Documents and Settings\YOUR USERNAME\.qgis\python\plugins
> >> The documentation I find says to use the "Fetch plugins"
> functionality
> >> for installing, but that requires an internet connection which the
> >> QGIS machine doesn't have. Are there manual install instructions?
> > unzip the file, and place the resulting folder into the
> > ".qgis/python/plugins" one you find in your system (under Windows
> that
> > folder is inside your c:/users/username folder).
> > cheers
> > -- giovanni --
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> with relevant legislation.
