[Qgis-user] Re: Swipe functionality
jonathanmoules at warwickshire.gov.uk
Wed Nov 2 01:16:01 PDT 2011
Yep, ArcGIS does the same thing under the same name too, so it's not an
uncommon feature.
Unfortunately I do need it to be a QGIS extension because we have a
pre-deployed QGIS project that is interested in it. However, it's an
"icing on the cake" feature, so not mandatory.
Thanks though,
Jonathan
From: Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>
To: qgis-user at lists.osgeo.org
Date: 02/11/2011 07:07
Subject: [Qgis-user] Re: Swipe functionality
Sent by: qgis-user-bounces at lists.osgeo.org
<jonathanmoules at ...> writes:
> Ah, these are multi-band images I'm using. The
> problem with QGIS relying on plugins is that you're also relying on the
> documentation for those plugins, and this one doesn't seem to have much
> for instance.Swipe basically allows you to "swipe"
> a raster layer off so you can compare it with what's below. Best
described
> with a video - http://www.youtube.com/watch?v=IBl0eKPE37I- see from ~55
seconds.Cheers,Jonathan From:
> Giovanni Manghi <giovanni.manghi at gmail.com>To:
Seems to be the same functionality and with the same name as in ERDAS
Imagine.
OSSIM can do it, see page 9 in this document
http://download.osgeo.org/ossim/docs/pdfs/ImageLinker_Tutorial.pdf
I am not sure how good OSSIM is with vector layers. OSSIM itself is
getting
better with vectors but Image Linker is quite old and not developed any
more.
However, it will not hurt to have a look at OSSIM if you want to do some
serious
raster processing.
-Jukka Rahkonen-
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111102/3c760ba3/attachment.html>
