[Qgis-user] GdalTools Proximity
Lolita Bizzarri
lolitabizzarri at gmail.com
Sat Nov 5 01:28:06 PDT 2011
Hi Giuseppe,
now it's ok, it works.
Thanks so much!
Regards.
On Nov 4, 2011, at 8:45 PM, Giuseppe Sucameli wrote:
> Hi Lolita,
> I'm sorry, I was wrong, the path I wrote contains an error.
> Set that path to gdal binaries to
> /library/frameworks/GDAL.framework/Versions/1.8/Programs:/usr/bin
> which is a list of colon-separated path:
> path to gdal binaries, colon, path to python executable.
> I hope this help.
> Regards.
> On Fri, Nov 4, 2011 at 5:48 PM, Lolita Bizzarri
> <lolitabizzarri at gmail.com> wrote:
>> I tried but doesn't work. The message is the same.
>> 2011/11/4 Paolo Cavallini <cavallini at faunalia.it>
>>> Il 04/11/2011 14:00, Giuseppe Sucameli ha scritto:
>>>> try to set the path to gdal binaries in GdalTools settings to
>>>> /bin/python2.6:/library/frameworks/GDAL.framework/Versions/1.8/
>>>> Programs/
>>> if this works, I think it should be added to an help or popup
>>> somewhere.
>>> all the best.
>>> Paolo Cavallini - Faunalia
>>> www.faunalia.eu
>>> Full contact details at www.faunalia.eu/pc
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giuseppe Sucameli
