[Qgis-user] Qgis-user Digest, Vol 69, Issue 21
William Kyngesburye
woklist at kyngchaos.com
Sat Nov 5 21:44:28 PDT 2011
My Sqlite3 framework, which my OSX Qgis uses, contains pyspatialite as a symlink to pysqlite (that's all it really is). Qspatialite loads for me. I haven't tried Mars' loading problem though.
On Nov 5, 2011, at 8:24 PM, Kurt Springs wrote:
> I haven't gotten that far. How did you load the pyspatialite python plug in? Whe I try to run Qspatialite it tells me it can't find pyspatialite. I tried to load it via the easy_install method, but it won't install.
> Kurt
> On Nov 6, 2011, at 12:00 PM, Mars Sjoden wrote:
>> Has anyone else found the following issue?
>> 1.
>> Using Mac OS X QGIS 1.7.1 - William Kyng.‚s Frameworks (Also occurs on
>> QGIS 1.8 Kyng.‚s)
>> 1.
>> Uploading a Medium sized shapefile to QspatiaLite
>> 1.
>> QGIS Layer
>> 1.
>> Use VirtualShape Import (*check ON*)
>> * BUG CRASH does not occur when [Use VirtualShape Import] check OFF
>> Reports and SHP:
>> Upload Tables QspatiaLite - Using VirtualShape Import -
>> https://docs.google.com/open?id=0B63BcSDiEI_7YzdkM2JkMTctMWRlMS00OWI2LWEwZDgtNDhiYmJhMTg5Yjg4
>> Publicly available Shapefile from:
>> http://geobc.gov.bc.ca/ DOWNLOAD -> Free Data -> [Guest Users Enter Here]
>> category:
>> *Configururable Products*
>> *Land and Natural Resources Information > Forests, Grasslands and Wetlands*
>> VRI - Forest Vegetation Composite Polygons and Rank 1
>> Mapsheet: 093L047
>> Mars
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
