[Qgis-user] Qgis-user Digest, Vol 69, Issue 21
    Kurt Springs
    ferret_bard at mac.com
    Sun Nov  6 08:56:30 PST 2011
I'm using OS X Lion.
I'm able to load QSpatiaLite form the fetch python plug-ins fine, but when I try to launch it I get "PySpatiaLite python module is required for QSpatiaLite".
I click okay, then get the QspatiaLite window.  Is it usable and the error message wrong, or is there a problem some were?
Kurt
On Nov 5, 2011, at 11:18 PM, Noli Sicad wrote:
> http://www.gaia-gis.it/spatialite-2.4.0-4/splite-python.html
> http://www.mail-archive.com/qgis-developer@lists.osgeo.org/msg05498.html
> Same instruction applies to Windows, Mac OS X or Linux.
> It is python.
> Noli
> On 11/6/11, Mars Sjoden <marsofearth at gmail.com> wrote:
>> On Sat, Nov 5, 2011 at 6:24 PM, Kurt Springs <ferret_bard at mac.com> wrote:
>> I haven't gotten that far.  How did you load the pyspatialite python plug
>>> in?  Whe I try to run Qspatialite it tells me it can't find pyspatialite.
>>> I tried to load it via the easy_install method, but it won't install.
>>> Kurt
>> Are you on Windows?? 1.7.1?  I'm more familiar with Linux or OS X.
>> On Nov 6, 2011, at 12:00 PM, Mars Sjoden wrote:
>>>> Has anyone else found the following issue?
>>>>  1. Using Mac OS X  QGIS 1.7.1 - William Kyng.‚s Frameworks (Also
>>> occurs on QGIS 1.8 Kyng.‚s)
>>>>  2. Uploading a Medium sized shapefile to QspatiaLite
>>>>  3. QGIS Layer
>>>  4. Use VirtualShape Import (*check ON*)
>>>> * BUG CRASH does not occur when [Use VirtualShape Import] check OFF
>>>> Reports and SHP:
>>>> Upload Tables QspatiaLite - Using VirtualShape Import -
>>> https://docs.google.com/open?id=0B63BcSDiEI_7YzdkM2JkMTctMWRlMS00OWI2LWEwZDgtNDhiYmJhMTg5Yjg4
>>>> http://www.keepandshare.com/visit/visit_page.php?i=1851910
>>> Publicly available Shapefile from:
>>>> http://geobc.gov.bc.ca/  DOWNLOAD -> Free Data -> [Guest Users Enter
>>> Here] - category:
>>>> *Configururable Products*
>>>> *Land and Natural Resources Information > Forests, Grasslands and
>>> Wetlands*
>>>> VRI - Forest Vegetation Composite Polygons and Rank 1
>>>> Mapsheet: 093L047
>>>> Mars
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
