[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Noli Sicad
nsicad at gmail.com
Wed Nov 9 03:12:21 PST 2011
Yes, I restarted QGIS in Mac OS X when I active and deactivate it.
It is not working in Mac OS X.
However, I just boot up Ubuntu. It works in Ubuntu. I was able to draw
rectangle, oval and circle geometry now.
Thanks.
Noli
On 11/9/11, Saber Razmjooei <razmjooeis at faunalia.co.uk> wrote:
> I think you only need Rectangles oval digitizing plugin (0.1.2)
> If you activate/deactivate it from plugin manager, I noticed I had to
> restart QGIS.
> Cheers
> Saber
> On Wed, 2011-11-09 at 21:59 +1100, Noli Sicad wrote:
>> OK. The inactive green rectangle is showing up again.
>> Installing the 0.1.2 Rectangle ovals digitizin plugin.
>> I also install the 0.1.6 Rectangle, Ovals, Diamonds.
>> What is the difference between these 2 plugins?
>> I installed one by one. It did not work. I installed both of the them,
>> it also did not work.
>> However, it is totally not working in Mac OS X.
>> Noli
>> On 11/9/11, Noli Sicad <nsicad at gmail.com> wrote:
>> > It was inactive. Nothing happened if you drag the rectangle.
>> > Now, I uninstalled and installed it again.
>> > Now, the icon inactive is gone.
>> > It is totally not working in Mac OS X QGIS 1.7.1.
>> > I will checked Ubuntu in few minutes. After I download Qt 4.7.4. It is
>> > quite big download 1.3G for Mac OS X.
>> > http://labs.qt.nokia.com/2011/11/08/qt-4-7-4-release-bundle-for-symbian-news/
>> > Thanks.
>> >> Select a shape from the toolbar, in the canvas: click and drag.
>> >> Cheers
>> >> Saber
>> >> On Wed, 2011-11-09 at 21:26 +1100, Noli Sicad wrote:
>> >>> OK. I saw it. Thanks.
>> >>> I am now in Mac OS X.
>> >>> My laptop is triple boot :-).
>> >>> I toggled the Pencil icon - edit, yet I could not make to change or
>> >>> use the defaullt rectangle to draw.
>> >>> How do you use this plugin?
>> >>> Noli
>> >>> > Works for me under Ubuntu 10.04.
>> >>> > The icon should be towards the end of your Digitizing toolbar. You
>> >>> > need
>> >>> > to click on it and hold to see other shapes.
>> >>> > Cheers
>> >>> > Saber
>> >>> > On Wed, 2011-11-09 at 16:38 +1100, Noli Sicad wrote:
>> >>> >> This plugin seems not to work with Ubuntu 10.04.
>> >>> >> Yes, I checked in QGIS manage plugin. It installed by I could see
>> >>> >> the
>> >>> >> icon and the menu entry in QGIS.
>> >>> >> I created a new shapefile and I toogle to edit. No icons showing in
>> >>> >> the toolbar that resembled or look like this.
>> >>> >> http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
>> >>> >> Any instruction how to make it work in Ubuntu?
>> >>> >> Thanks.
>> >>> >> Noli
>> >>> >> On 10/22/11, Pavol Kapusta <pavol.kapusta at gmail.com> wrote:
>> >>> >> > Hello,
>> >>> >> > i would like to introduce you the new Rectangles ovals digitizing
>> >>> >> > plugin.
>> >>> >> > This plugin is available in QGIS Contributed Repository and after
>> >>> >> > installing creates three new objects in Digitizing toolbar: one
>> >>> >> > multifunction button with digitizing tools, one button for
>> >>> >> > rotation
>> >>> >> > of
>> >>> >> > rectangles or ovals and spinbox for changing of number of
>> >>> >> > segments
>> >>> >> > for
>> >>> >> > ovals. There are 6 digitizing tools: "Rectangle by extent",
>> >>> >> > "Rectangle
>> >>> >> > from center", "Square from center", "Circle from center",
>> >>> >> > "Ellipse
>> >>> >> > by
>> >>> >> > extent", "Ellipse from center". Plugin is active only when you
>> >>> >> > are
>> >>> >> > editing polygon layers. Tools, which have "from centre" in the
>> >>> >> > name
>> >>> >> > are
>> >>> >> > able of snapping (after defining in Snapping Options tab of
>> >>> >> > Settings)
>> >>> >> > of the virtual center of feature.
>> >>> >> > "Rotation tool" is functional after selection of (exactly) one
>> >>> >> > rectangle or oval.
>> >>> >> > After digitizing of feature, there is Feature form with
>> >>> >> > possibility
>> >>> >> > of
>> >>> >> > changing default attribute values. You can deactivate this in
>> >>> >> > Settings
>> >>> >> > -> Options -> Digitizing tab -> "Suppress attributes pop-up
>> >>> >> > windows
>> >>> >> > after each created feature". Option "Reuse last entered
>> >>> >> > attribute
>> >>> >> > values" is not supported.
>> >>> >> > I hope you will find this tools useful.
>> >>> >> > Regards
>> >>> >> > Pavol
>> >>> >> > _______________________________________________
>> >>> >> > Qgis-user mailing list
>> >>> >> > Qgis-user at lists.osgeo.org
>> >>> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
