[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Arif Arham
arhamilis at gmail.com
Thu Nov 10 01:51:32 PST 2011
Try open a vector layer, first.
On Wednesday, November 9, 2011, Noli Sicad <nsicad at gmail.com> wrote:
> Yes, I restarted QGIS in Mac OS X when I active and deactivate it.
> It is not working in Mac OS X.
> However, I just boot up Ubuntu. It works in Ubuntu. I was able to draw
> rectangle, oval and circle geometry now.
> Thanks.
> Noli
> On 11/9/11, Saber Razmjooei <razmjooeis at faunalia.co.uk> wrote:
>> I think you only need Rectangles oval digitizing plugin (0.1.2)
>> If you activate/deactivate it from plugin manager, I noticed I had to
>> restart QGIS.
>> Cheers
>> Saber
>> On Wed, 2011-11-09 at 21:59 +1100, Noli Sicad wrote:
>>> OK. The inactive green rectangle is showing up again.
>>> Installing the 0.1.2 Rectangle ovals digitizin plugin.
>>> I also install the 0.1.6 Rectangle, Ovals, Diamonds.
>>> What is the difference between these 2 plugins?
>>> I installed one by one. It did not work. I installed both of the them,
>>> it also did not work.
>>> However, it is totally not working in Mac OS X.
>>> Noli
>>> On 11/9/11, Noli Sicad <nsicad at gmail.com> wrote:
>>> > It was inactive. Nothing happened if you drag the rectangle.
>>> > Now, I uninstalled and installed it again.
>>> > Now, the icon inactive is gone.
>>> > It is totally not working in Mac OS X QGIS 1.7.1.
>>> > I will checked Ubuntu in few minutes. After I download Qt 4.7.4. It is
>>> > quite big download 1.3G for Mac OS X.
http://labs.qt.nokia.com/2011/11/08/qt-4-7-4-release-bundle-for-symbian-news/
>>> > Thanks.
>>> >> Select a shape from the toolbar, in the canvas: click and drag.
>>> >> Cheers
>>> >> Saber
>>> >> On Wed, 2011-11-09 at 21:26 +1100, Noli Sicad wrote:
>>> >>> OK. I saw it. Thanks.
>>> >>> I am now in Mac OS X.
>>> >>> My laptop is triple boot :-).
>>> >>> I toggled the Pencil icon - edit, yet I could not make to change or
>>> >>> use the defaullt rectangle to draw.
>>> >>> How do you use this plugin?
>>> >>> Noli
>>> >>> > Works for me under Ubuntu 10.04.
>>> >>> > The icon should be towards the end of your Digitizing toolbar. You
>>> >>> > need
>>> >>> > to click on it and hold to see other shapes.
>>> >>> > Cheers
>>> >>> > Saber
>>> >>> > On Wed, 2011-11-09 at 16:38 +1100, Noli Sicad wrote:
>>> >>> >> This plugin seems not to work with Ubuntu 10.04.
>>> >>> >> Yes, I checked in QGIS manage plugin. It installed by I could see
>>> >>> >> the
>>> >>> >> icon and the menu entry in QGIS.
>>> >>> >> I created a new shapefile and I toogle to edit. No icons showing
in
>>> >>> >> the toolbar that resembled or look like this.
http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
>>> >>> >> Any instruction how to make it work in Ubuntu?
>>> >>> >> Thanks.
>>> >>> >> Noli
-Arif
___________________________
KhazanahArham.wordpress.com <http://khazanaharham.wordpress.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111110/9043df87/attachment.html>
