[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Noli Sicad
nsicad at gmail.com
Thu Nov 10 02:47:34 PST 2011
Arif,
Have you make it working in Mac OS X?
Yes, I created first a vector layer. It means also that it opens a
vector layer before I do the digitizing.
From, Menu, Layer -> New -> New Shapelayer (Polygon) before digitizing.
It is working in Ubuntu 10.04, not in Mac OS X.
Noli
On 11/10/11, Arif Arham <arhamilis at gmail.com> wrote:
> Try open a vector layer, first.
> On Wednesday, November 9, 2011, Noli Sicad <nsicad at gmail.com> wrote:
>> Yes, I restarted QGIS in Mac OS X when I active and deactivate it.
>> It is not working in Mac OS X.
>> However, I just boot up Ubuntu. It works in Ubuntu. I was able to draw
>> rectangle, oval and circle geometry now.
>> Thanks.
>> Noli
>> On 11/9/11, Saber Razmjooei <razmjooeis at faunalia.co.uk> wrote:
>>> I think you only need Rectangles oval digitizing plugin (0.1.2)
>>> If you activate/deactivate it from plugin manager, I noticed I had to
>>> restart QGIS.
>>> Cheers
>>> Saber
>>> On Wed, 2011-11-09 at 21:59 +1100, Noli Sicad wrote:
>>>> OK. The inactive green rectangle is showing up again.
>>>> Installing the 0.1.2 Rectangle ovals digitizin plugin.
>>>> I also install the 0.1.6 Rectangle, Ovals, Diamonds.
>>>> What is the difference between these 2 plugins?
>>>> I installed one by one. It did not work. I installed both of the them,
>>>> it also did not work.
>>>> However, it is totally not working in Mac OS X.
>>>> Noli
>>>> On 11/9/11, Noli Sicad <nsicad at gmail.com> wrote:
>>>> > It was inactive. Nothing happened if you drag the rectangle.
>>>> > Now, I uninstalled and installed it again.
>>>> > Now, the icon inactive is gone.
>>>> > It is totally not working in Mac OS X QGIS 1.7.1.
>>>> > I will checked Ubuntu in few minutes. After I download Qt 4.7.4. It is
>>>> > quite big download 1.3G for Mac OS X.
> http://labs.qt.nokia.com/2011/11/08/qt-4-7-4-release-bundle-for-symbian-news/
>>>> > Thanks.
>>>> >> Select a shape from the toolbar, in the canvas: click and drag.
>>>> >> Cheers
>>>> >> Saber
>>>> >> On Wed, 2011-11-09 at 21:26 +1100, Noli Sicad wrote:
>>>> >>> OK. I saw it. Thanks.
>>>> >>> I am now in Mac OS X.
>>>> >>> My laptop is triple boot :-).
>>>> >>> I toggled the Pencil icon - edit, yet I could not make to change or
>>>> >>> use the defaullt rectangle to draw.
>>>> >>> How do you use this plugin?
>>>> >>> Noli
>>>> >>> > Works for me under Ubuntu 10.04.
>>>> >>> > The icon should be towards the end of your Digitizing toolbar. You
>>>> >>> > need
>>>> >>> > to click on it and hold to see other shapes.
>>>> >>> > Cheers
>>>> >>> > Saber
>>>> >>> > On Wed, 2011-11-09 at 16:38 +1100, Noli Sicad wrote:
>>>> >>> >> This plugin seems not to work with Ubuntu 10.04.
>>>> >>> >> Yes, I checked in QGIS manage plugin. It installed by I could see
>>>> >>> >> the
>>>> >>> >> icon and the menu entry in QGIS.
>>>> >>> >> I created a new shapefile and I toogle to edit. No icons showing
> in
>>>> >>> >> the toolbar that resembled or look like this.
> http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
>>>> >>> >> Any instruction how to make it work in Ubuntu?
>>>> >>> >> Thanks.
>>>> >>> >> Noli
> -Arif
> ___________________________
> KhazanahArham.wordpress.com <http://khazanaharham.wordpress.com>
